Results 1 to 7 of 7
    Old Bridge, NJ
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier 19DK external oil filter upgrade
    I'm going to change from the OEM type that's in the pump to an external cartridge type. I'm wondering if I need to do anything to the regulator. The filter will be downstream of the regulator. Does anyone have any Bulletins or upgrade directions?
    in a tree looking in your window
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I put one of these York filters on a burnt up 19XL one time and didn't have any problems
    You know your a stud in the bedroom when the girl your raping comes before you and the cops
  3. Likes ruuufuhbock liked this post.
  4. #3
    Dover, Pa.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nice pic !
    I have also done the same with no issues a 3 of those machines
    Good mechanics are getting harder to find.....have you encouraged or discouraged a young mechanic today?
  5. #4
    Windsor ON Canada
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There was a service bulletin put out by Carrier to perform this upgrade. I have been retired for a few years and unfortunately I do not have access to it....so I have to rely on memory. The internal relief was modified to stay in the closed position to allow for an external regulator. A piece of 1/2" or 5/8" diameter copper, (you can confirm diameter when you have access to the regulator) was cut 1/2" long and inserted inside the existing regulator (the spring and the piston remain). This effectively sealed the regulator closed and allowed full pump pressure to the oil filter canisters. A new regulator was installed downstream of the filter canister and vented back into the oil sump. I used an oil regulator from a 19C chiller which allowed for oil pressure adjustment once all was up and running. Hope this info helps you.
  6. #5
    Dec 2014
    New Mexico
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hw chiller man View Post
    That’s what I remember as well.
  7. #6
    up in the hizzy
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here the SB
    Attached Files Attached Files
    There is not better place for the working men than the union! 100% UA the only HVAC union!
  8. #7
    Apr 2009
    Columbus,Ohio
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Info. for external oil filter
