Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 64
  1. #40
    Nov 2011
    East Side
    You guys have your pressures way too high. 7/7 are the standard clean flame pressures.
    You can braze exactly the same with a small tip, a rosebud, a hook, etc. at 7/7. Adjust at the handle as needed.....you’re just wasting gas any higher than that.
    Those pressures will suffice for most any standard brazing we do. Getting into 3” of more, you’ll need more pressure.
  2. Likes The Turtleman liked this post
  3. #41
    May 2014
    Bay Area California
    LOL
    Wasting gas? When the gas is throttled back? I always get a kick out of it when I hear someone say that.
    That's why God put knobbies on the torch handle.
    Quote Originally Posted by 71CHOPS View Post
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
  4. #42
    Aug 2018
    Piedmont Triad, NC
    Well, I think I might have just fallen for staybrite 8. After realizing I’ve been using a # 0 tip for brazing I tried soldering with it. 30 seconds later I had a decent joint. I even cut it in half with band saw to check it. 6 psi ace and 11 psi oxy for the win. Anyone have any staybrite 8 horror stories? Maybe I should make a thread about that...
  5. #43
    Aug 2018
    Piedmont Triad, NC
    Hmmm, now that I’m looking at it the flux on the inside of the pipe may be a problem. I can just picture POE oil picking it up and eventually wearing away the insulation over the windings.
  6. #44
    Nov 2011
    East Side
    Quote Originally Posted by BBeerme View Post
    LOL
    Yup....if you’re throttling 20 psi, vs 7 psi, you’re using more gas at 20.
  7. #45
    Dec 2009
    maroon lazyboy
    It’s been a long week. Help me understand how a manual regulator (knob) 8” from the flame, lowers the gas pressure less efficiently than the tank regulator. Thx.
  8. #46
    Dec 2009
    maroon lazyboy
    Using a rose bud to weld in a captube, ..... that could waste some gas...
  9. #47
    Chicago area
    Quote Originally Posted by knave View Post
    I dont think it matters where the pressure drop occurs, but the regulator is more efficiently doing it.
    With a bigger tip, probably not much of an issue. Smaller tip, then the throttle point on the knob may need to be too low if using a higher pressure, especially if the needle and seat are worn in the valve body.
  10. Likes ChuckDe liked this post
  11. #48
    Nov 2011
    East Side
    We can argue about it all day long, but if you set your regulators to 7/7, you’re going to braze the same as you would with 10/30.
    Unless you’re brazing 3” lineset, you’ll do just fine.
  12. #49
    Nov 2011
    East Side
    Which brings up the point of why do you have to set the regulator so high, if you think the valves regulate the gas flow just as well?
  13. Likes The Turtleman liked this post
  14. #50
    Dec 2009
    maroon lazyboy
    Haha! good comeback there and a good point as well, lol
  15. #51
    Chicago area
    I set mine the same way. Balance pressure.
  16. #52
    May 2014
    Bay Area California
    If you have the same flame, the same amount of gas coming out of the tip, you are not using more gas.
    For me, you need that higher pressure when you put on a cutting tip. Plus, when I'm through with the soldering, brazing, or welding, then I turn up the oxy to blow the flame out. Can't do that with low pressure.
