Results 1 to 10 of 10
    Dec 2018
    Ventura, CA
    Gas valve rerplacement
    Need to replace an existing millivolt gas valve for a customer. They want the same type of valve with the knob so they can adjust the flames. What would be a good replacement valve for this?
    Thanks a lot
    Jan 2015
    Iowa
    I would ask the manufacturer of the fireplace if they have or recommend something, I would not change it to something different without their approval. Liability is too high
    Good luck
    Mar 2016
    Pahrump, NV
    I haven’t found that replacing a gas control valve on a fireplace is cost effective for the customer.
    The price of the valve alone is often about half the price of a new unit.
    After I add in my service call to diagnose the bad valve, time for finding and ordering the part, converting to LP (if required), removing and installing the new valve, and testing the equipment, it is cheaper for the customer to get a whole new unit.
    It's an upside down world we live in.
    Dec 2018
    Ventura, CA
    Quote Originally Posted by Answer-Man View Post
    Good luck
    Thanks. Sorry Just to clarify; old valve was able to adjust the flame height so I’m not trying to change anything. Customer just wants the same type of valve. Fireplace is probably over 40 years old without any numbers on it or the valve.
    Jan 2015
    Iowa
    If it's 40 years old, what Mr Goodman said
    Dec 2018
    Ventura, CA
    Quote Originally Posted by David Goodman View Post
    Thanks for the advice. What gas valve are you thinking of that is so expensive?
    Mar 2016
    Pahrump, NV
    Quote Originally Posted by navyguy1 View Post
    DESA parts are common in the brands around here.
    Mar 2015
    Hamersville, Ohio
    Thanks a lot
    Navy,
    Have You contacted the Manufacturer of the Fireplace?
    Well, .... I reckon that's what happens when one replies to the first post, & then reads the other replies.
    If this unit is truly 40 years old, ..... Then it needs to be thoroughly checked from one end to the other/ Inside out.
    I've always been able to get some form of Data, on a unit, whereas I could identify it, & chase down parts/ tech support etc.
    "If" Tags/ Data plates have been removed, that is a Red Flag right there about some form of problem, be it the Equipment &/or the forgetful (Bungling) "Servicer" that didn't have a pencil & notepad handy.
    Worse yet, .... If the Data plate/ decals are wore off due to Moisture/ High heat/ Abuse, ..... Then sell the H.O. a New Unit, with Warranty, that should be far more efficient than a "40 year old" unit.
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
    Athens, Ohio
    At 40 years of age, there’s a good chance the part and fireplace are obsolete.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by kdean1 View Post
    <<< My "Modified Like Button".
