Results 1 to 20 of 23
Thread: Sitelink local access
    Jun 2009
    I've read a USB-K cable is needed to access the local access port on a sitelink. Is this just a USB to RS485 cable?
    Stan
    May 2009
    SC
    Yes.
    Jun 2009
    Cool! Thanks!
    Did you used to worked for Liebert? I remember a fellow name Scott that worked there. Can't recall his last name though. I think he took Wes's place when he retired many years ago. I met Wes and Scott not too long before Wes retired.
    Stan
    May 2009
    SC
    Yes, I was with Liebert in California and Massachusetts. Ten years total.
    Jun 2009
    Cool! I thought you might be one of the fellows that was with Wes when they came to the place I work many years ago. I don't think you are though. I learned a fair amount about sitescan and sitebuilder from watching Wes and other Liebert/Emerson techs that came onsite to upgrade and add things in sitescan. No expert by any stretch, but I know my way around it pretty well.
    What I'm trying to accomplish is change the IPs on a couple of sitelink-e's that are in some Liebert FPC's that power the lab in a mini data center we put back in the old data center after it was remodeled.. Originally we had a sitescan system in the old data center that these were in. No more sitescan system now. But I'm wondering if the sitelink-e's will talk MODBUS I know they were configured for BACnet. It's been too long, I can't remember if they were also configured for MODBUS. If so, I can add them in NEO since it's pretty easy to configure MODBUS in NEO. Like I said before, BACnet is another bowl of wax in NEO. If the sitelink-e's won't do what I want; I guess the other option is another controller. Bill at Vertiv told me these FPC's talk MODBUS natively.
    Thanks for your help.
    Stan
    May 2009
    SC
    I did national tech support and flew all over this half of the world doing that stuff. I'm trying to picture Wes but I'm failing, name sounds familiar though. All my Liebert knowledge is out of date now but they used to have a edit graphic for the equipment that would write in the third party modbus URLs to the equipment, one click per device connected to do that. Then any one had a button to configure the driver, only need be done on one. Very easy if all that works. Lots of typing if it doesn't to get the URLs straight. Driver is easy to set up manually.
    Jun 2009
    Ok.
    Wes was the sitescan guru in Columbus. It's been too long, I can't recall his last name. He was a bit set in his ways is how I'd describe him.
    If I get a serial to RS-485 adapter and make a cable, do you know the pinout of the 5 pin local access connector on the sitelink-e? Or can the RNET port be used for local access also?
    Stan
    California
    Quote Originally Posted by MaxBurn View Post
    Man, way off topic. Guess you knew Shalabh?
    Controls, the cause of... and solution to... all your HVAC problems.
    May 2009
    SC
    Quote Originally Posted by stan-g View Post
    ~ can the RNET port be used for local access also?
    Yes
    Quote Originally Posted by control$ View Post
    Gupta I think was his last name. Believe we met a couple times but we were all work from home people in Monitoring NTS and rarely got together as a group.
    Jun 2009
    Ok. Thanks.
    We did stray a bit off topic, but I thought you were someone I met long ago. Looks like that's not the case. Sorry moderator.
    Will see what I can come up with when I get the RS-485 adapter.
    Unsure what you mean about the URL's. Is the sitelink-e a standalone web server like a JCI NAE? Or does Automated Logic do like EMC did long ago with a web interface that's accessible via a serial connection. I forget what that type of connection is called. I'm getting old and forgetful..
    Stan
    Jun 2009
    After getting the RS-485 adapter and connecting it to the Rnet, I was able to change the IP, subnet and gateway on the sitelinks. BUT, it appears as though they only have BACnet configured on them. No luck trying to talk to them MODBUS when I tried with the Schneider tool "tester" For a little while longer, I do have a sitescan 6.x system. Until the folks that are a pay grade or two above me decide to get rid of it. Not sure it will do me much good though. The way we used to have sitescan setup was using a single system that had multiple data center, which are spread across the country, all on one system. But, the old branch of the tree that had the sitelinks was pruned long ago and I can't find a backup I used to have before it got pruned Guess I'm up the creek unless sitebuilder or one of the other tools can retrieve the programming from the sitelinks and I'm able to add the MODBUS protocol. I guess webctrl is the only thing that will retrieve the programming from the sitelinks? Or is there a way to do it with sitebuilder or another tool?
    Stan
    May 2009
    SC
    You might still have the files needed but yeah, bit of work setting it up in sitebuilder.
    California
    Do a modest and you'll get the program name and device instance. Liebert's where pretty canned, so chances are someone here has it. Then recreate in Sitebuilder.
  14. #14
    Jun 2009
    I can talk to it with sitebuilder. I did a modstat and figured out what driver I needed. Now, if I can remember how to recreate it in sitebuilder... It's been forever and a day since I messed with it.
    Thanks everyone for your help.
    Stan
  15. #15
    Jun 2009
    I remembered enough in sitebuilder to build a simple site and got the first sitelink to communicating BACnet. The other one is being a pain. w-pm was the right control program for the first FPC, but the other one seems to have a different controller. I tried w-pm2 and it didn't like that either. Dang it. When/if I do get both going; how do I make them talk MODBUS?
    Stan
  16. #16
    May 2009
    SC
    Liebert had a edit graphic that would enter the URLs into the program and set up the driver.
  17. #17
    Jun 2009
    Ok. I think I know where that is.
    I can't type today. I meant the w-pmp control program is the one that worked with the first FPC. I would think the other one would be the same since they are the same vintage. Maybe it has a loose connection. It keeps failing with a communications failed error when it starts to check the controller type when I download the sitelink in sitescan.
    Slowly getting there
    Thanks again for your help.
    Stan
  18. #18
    Jun 2009
    I don't see the edit graphic. But, I may be attempting something that isn't going to work. What I was hoping for was the sitelink-e being able to do MODBUS TCP/IP so I could monitor the FPCs using NEO. NEO will talk MODBUS TCP/IP. That's how I monitor the 8 CW084 CRAH units we have in the little data center. They have Intellislot cards in them though. But, a search I did on the archive seem to indicate the sitelinks won't read MODBUS type 3 and 4 registers. Is that correct? It sounds like I have no choice but to do this BACnet and build NEO polling server machines in the same network subnet as the sitelinks I thought about trying to setup a BACnet router using one of the sitelinks, but I don't think that will help. Not sure I still recall how to do that. I forget what all goes in the BBMD table.
    Stan
  19. #19
    California
    Do you mean function 3 and 4? They do.
  20. #20
    Jun 2009
    I think so. The read holding registers and read input registers is what I meant.
    Stan
