Results 1 to 7 of 7
    May 2019
    Triton T200 Boiler Error code.
    For 3 months now the boiler has been going into lockout code 109. I'm new to working on this boiler and have no clue where to start to get it to run. I have been told the Honeywell board is no good but cant find one to replace it with. Any help with this issue would be greatly appreciated.
    Jul 2018
    Quote Originally Posted by timothy.murphy View Post
    According to the manual, it's an ignition failure. It says to check the following:
    1. Check pilot valve (Main Valve for DSI) wiring and operation -
    correct any errors.
    2. Check the fuel supply.
    3. Check fuel pressure and repeat turndown tests.
    4. Check ignition transformer electrode, ame detector, ame
    detector siting or ame rod position.
    5. If steps 1 through 4 are correct and the fault persists, replace
    the module.
    Jul 2018
    Does it try to ignite? Does it fire up, for only a few seconds? Need more details...
    May 2019
    Sometimes runs fine for a few days sometimes only couple hours. Some times cant get it to relive at all.
    Jul 2018
    Did you see my previous reply? Go through those steps and let me know what you find.
    May 2019
    yes sir working through that list now. at the moment im also being told that the honey well board is no good. so we shall see.
    Chicago area
    Always start by doing maintenance on the burner, pilots, flame rods, ignitors, etc...
