Results 1 to 10 of 10
Thread: Wireless JACE
    Aug 2008
    Wireless JACE
    how do i enable wireless access on a jace 8?
    Greater Atlanta Area
    Jul 2002
    I've never done it. Is it a paid extra?
    Mar 2018
    No, comes standard. You just need to go in to the platform and enable the WiFi and turn the physical WiFi switch on to the left (access point) or right (don’t remember).
    Sep 2012
    New York, NY
    Wireless JACE
    I use it on every job I have. Set it up once and never plug in again.
    In platform/WiFi config, access point tab. Configure the WiFi name, password and timeout to 0 (otherwise the connection will close in 10 mins) and enable WiFi on top.
    Then toggle the WiFi switch to the left (acc).
    Log into the WiFi name and use the WiFi up address (192.168.11.1)
    Knowledge is money - Ignorance is expensive!!
    Dec 2006
    Washington, DC
    Quote Originally Posted by incontrol View Post
    It is a paid extra for one with the wireless radio disabled. I have had an Army & Navy base that required the wireless function to be non-functional, not just disabled in the settings.
    Quote Originally Posted by Qui-Gon Jinn (Star Wars Episode 1)
    "The ablilty to speak does not make you intelligent!"
    Aug 2008
    Quote Originally Posted by vaultein View Post
    i am using AX on a 3.8 JACE 8. i do not see a wifi config in my platform.
    I don’t believe you can use WiFi on Jace-8 when running a 3.8 station. I think you need to be running N4
    SE Pennsylvania
    Quote Originally Posted by gazoo View Post
    Does not work in other than N4. It's stated in the start of the documentation posted above
    Sep 2012
    New York, NY
    You won’t find the WiFi config in AX only N4.
    You may be able to set it up in N4 platform and then try logging into it in AX.
    Never tried that.
