Results 1 to 7 of 7
    Apr 2019
    Where to refill Helium Gas Cylinder?
    Hi…
    I am using Helium gas cylinder to inflate balloons. It will enhance the look of my party and events. I have a doubt that where can I refill the helium Gas cylinder if it is empty?
    Jul 2018
    Wisconsin
    You will have to get a cylinder from a gas supplier like Airgas. You will pay a deposit on the cylinder. When it is empty you can bring it in and exchange it for a full one paying for the gas only. Otherwise you will be stuck with disposable tanks from the Party store or Walmart.
    Jan 2010
    Quote Originally Posted by Spitz View Post
    What Spitz said
    Jan 2012
    Broomall, PA
    Might be easier to just ask your nearest party supply store who they use.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    now why would a party store give that info out and lose the money becasue they sent you to that stores source
    Jan 2012
    Broomall, PA
    Quote Originally Posted by pctech View Post
    Ahh top secret military grade helium.
    Oct 2014
    Columbus, Ohio
    You can't refill a disposable cylinder and you should not try to. If you go through a lot of gas, get a larger rental tank from Airgas and make sure that it is a party blend, not straight helium. The blend contains some oxygen in order to prevent inhalation deaths.
    Apr 2019
    Dubai, UAE
    Well, Here is the best solution for you, By contacting Balloonee it's easy to refill a Helium gas cylinder they are providing good service recently I have purchased a helium balloon kit and I am very much attracted to it. Give a try and share your thoughts.
