Results 1 to 13 of 13
    Aug 2015
    mexia tx
    RDI Model PC199LOP-2
    I would appreciate some help Customer walk-in freezer is tripping the 30amp break several times a day. Model # PC199LOP-2 serial 410081537. Another tech had installed a new start capacitor and run capacitor and left. System still trips. I check all the wiring all good check inside breaker panel even swap the 30amp breaker. Od Fan motor amps 1.9, compressor amps were 12amps RLA says should be 16amps. When the breaker rests it runs smooth for a few hours and then trips. I need to ohm the compressor what would indicate a felling compressor? I’m leaning to maybe a defected fan motor or even dump the charge evac to 250 and weigh in a new charge because previous tech cut out the high pressure switch. Any suggestions
    kansas
    You should ohmn before you reset or swap breakers. Why would a hps be bypassed and left. Have you checked and ohmn Ed the defrost circuit
    Apr 2010
    California
    Quote Originally Posted by g.lawson View Post
    I think You are leaning in the Right Direction. It has all the Symptoms of a Cond. Fan Motor, "Internal Protector", "Intermittent Open" on heat scenario to me. Clean the Cond. Unit Coil, Clean the Fan Motor Cooling Slots, Remove ALL Jumpers, Install a Voltage, or Current Monitor Device, and Wait for the next trip. While Your Waiting, Locate a replacement Cond. Fan Motor, and dust off your fan blade hub puller tool, "in case you need them". Good Luck.
    Aug 2015
    mexia tx
    Other company changed the run and start caps. He called them back they said over the phone he needs a new compressor. The owner and I members of the same lodge. Thanks I let you know what it turns out to be.
    Jul 2000
    Guayaquil, EC
    The RLA stated on the data plate of the unit isn't the amperage the compressor should run at. It's a calculated amperage which should only be used as a maximum operating amps or to size a contactor, breaker, etc. A better way to determine if the compressor is doing what it's supposed to do is to use the manufacturer's performance data for that compressor. If it's a Copeland, you can use their Copeland Mobil app which is available for iPhone, Android and desktop.
    As for the breaker tripping, first verify that the defrost is not coming on while the compressor is running, such as after a pumpdown has been initiated. Typically the defrost is interlocked off by a relay or by an auxiliary set of contacts on the compressor contactor.
    Apr 2010
    California
    "They Said", Always Good To Know! Lol.. Just Replace the Entire Condensing Unit while You are at It. !
    Aug 2015
    mexia tx
    There’s a lot guys out there that would have no problem doing that, but I would lose sleep doing that to a customer.
    Apr 2010
    California
    Me Too, in My funny way of Expressing It.!!!!!!
    Apr 2010
    California
    Quote Originally Posted by lzenglish View Post
    So, Whatcha Gonna Do Now ? Either Troubleshoot and Repair, or Replace.! Remember this, "Head Psi Up,= Current Up,= Thermals Open, And Breakers Trip" ! hint-hint!
    Southold, NY
    Wires rub out!
    Apr 2010
    California
    Wires rub out!
    "Wires Rub Who"? All in Good Fun New York Bro.......
    Southold, NY
    Say What?
    Aug 2015
    mexia tx
    checked everything compressor amps 12-15, condenser fan .9 amps nothing is grounded, defrost works fine the compressor not running during defrost and checked to make sure the defrost heater are not running during a call for cool. the intermitted breaker tripping happens on warm days. I washed the condenser, installed a new high pressure switch, adjusted the charge. So far so good waiting see how it does in the afternoon heat. RDI is made by Manitowoc called them of course parts department answered right away but when I tried their service department I would get the "please a detailed mgs and we will call you back, lol
