Results 1 to 11 of 11
    Nov 2014
    Northern Idaho
    Testing with DMM on small harnesses
    Im sure most if you have encountered the same issue as me, when trying to stab your test probes into micro looking harness plug. I havent found a good way to test the ones that are too small to for a standard probe.
    Curious to hear how you guys have overcame this
    Mar 2016
    Pahrump, NV
    It's an upside down world we live in.
    Jul 2011
    DFW, TX.
    Quote Originally Posted by GoCougs View Post
    IIRC i bought the fluke test probe kit. But b4 id just use t stat wire
  4. Likes vin lashon liked this post
  5. #4
    Been looking at automotive tips. Seems like a bigger selection.
  7. Likes CEAS-AC-TECH, vin lashon liked this post
  8. #6
    Dec 2012
    columbus, OH
    Ive been using paper clips cut off, just dont punch then thrue the tip of your finger...
  9. Likes CEAS-AC-TECH, BALloyd liked this post
  10. #7
    Nov 2011
    East Side
    I use the FP needle probes. Fluke makes them also
  11. Likes CEAS-AC-TECH liked this post
  12. #8
    May 2018
    I use Probemaster probes with needle points, work on everything!
  13. #9
    Jan 2001
    A file can come in handy... file down the tips to what you need. I needed a thin flat tip a while back and I grabbed a pair of those cheap leads that come with fluke meters... and filed the tips down on them.
    The bible is my constitution and the constitution is my bible.
    WE THE PEOPLE refers to THEM and not YOU.
    Chewbacca Mom 2016
  14. #10
    May 2013
    Highly recommended:
    https://www.fluke.com/en-ca/product/...ips/fluke-tp82
    Note, they are only rated for 60vdc. Don't tell anyone, but I've used them on higher voltage. Plus, not great for solid conductor cable. Perfect for typical low voltage control wiring found in hvacr equipment.
  15. #11
    Quote Originally Posted by corny View Post
    My trouble for the most part is the plastic part. You can't get two leads close enough together.
  16. Likes CEAS-AC-TECH liked this post
