Results 1 to 13 of 31
    Apr 2019
    Roanoke Rapids, NC
    Copper tubing benders. Is the price worth it?
    I am trying to decide if buying a copper tubing bender is really worth it? Most of my competition just solders in elbow and it pretty easy to bend a sweep into a pipe... Do anyone have any suggestions?
    Mar 2019
    Quote Originally Posted by garrej View Post
    IMO they are definitely worth it. Not only will it pay for itself in not having to constantly buy fittings but it also means you only have to do half the brazing thus half amount of contamination from soot and half the chance for leaks
  3. Likes Harris&harris liked this post
  4. #3
    Jun 2006
    Definitely worth it.
  5. #4
    Jun 2014
    Dover, DE
    I’ve borrowed this photo from another professional member of the site that is extremely talented with a bender.
    I take absolutely zero credit for this work. Full credit to member @ billg.
    I’ll let you decide, does it look better then sweat joints?
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Local 486
  6. #5
    SW Ohio
    A good swedger if you dont already have one.
    Ratchet bender is used more often but I prefer my lever benders when repiping compressors etc.
  7. #6
    New Mexico
    Ridgid made a ratchet bender that was made for hard copper. I knew a plumber that could do a house very fast with just a few fittings. He was faster with the bender than sweating.
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
  8. #7
    Oct 2011
    Gladstone, Oregon (Portland)
    One of the smartest tools you will ever buy.
  9. #8
    Fuquay Varina, N.C.
    Have to agree, two of the best tools I ever bought were the bender and the swedger tool, almost never bought another fitting and the swedger saved a lot of time and fittings
    Sent from my iPad using Tapatalk
    RSES Member.
    Mainstream Engineering Certified.
    HVAC/R PM Technician.
    410A, & GREEN HVAC/R Technician.
    Indoor Air Quality Master Technician.
    NATE Core.
    Working not as to please men but to the Glory of Christ my KING.
  10. #9
    Aug 2013
    Templeton MA
    Quote Originally Posted by rider77 View Post
    Beautiful work
  11. #10
    Jan 2015
    Iowa
    You will need the bender and sedger and the fittings all three. Sometime you just can't get where you need to be by just using one (bender or fittings)
    By the way the bending work above is some of the nicest work I've seen
  12. #11
    May 2015
    KS
    Be sure and get the reverse bending attachment if you buy the ratchet style bender.
    It allows you to make the bend from the outside of the bend
    Use it just as much as bending from the inside.
  13. #12
    Sep 2015
    Ontari-ari-ari-o
    Bending by hand gives you passable work. Using proper benders gives you professional looking work. Pick which one you want your name attached to forever.
  14. Likes Jay g ac liked this post
  15. #13
    Apr 2010
    California
    If You are in the Hvac/r Trade, or Plan to be in the Hvac/r Trade, a Tube Bender is a "Must Have"! No Questions about it, Period, end of My Story! One day you will realize, that the less copper fittings you add to the run, the less likely it is for Leaks to develop.
