    Jun 2017
    1 inch to 4 Inch Filter Conversion
    I have a two zone central AC system with three ceiling return intakes with 1 inch thick filters (one for the first floor and two for the second floor). I'd like to retrofit the returns to accommodate 4 inch filters since my wife has allergies and the 1 inch filters can't filter out the allergens without unacceptable air flow restrictions.
    Looking at the filter frame, it seems like an easy job to replace the 1 inch frames with 4 inch frames. There is sufficient clearance and I'd like to do the job myself. Despite my best attempts, I didn't get anywhere when searching online for return filter housing/box, etc. I see a lot of filter grilles but can't seem to find the boxes.
    I would appreciate some help with the right term for what I'm looking for and some places that sell these frames. I need a 12x12, 12x24 and 24x24.
    Thanks for your help.
    Southold, NY
    Quote Originally Posted by c210flyer View Post
    You'll need a contractor on site to take static pressure readings too see if the equipment can handle the extra resistance of pleated filters and make the modifications to the duct work!
    Jun 2017
    Thanks for the prompt response Pecmsg. But I'm a bit confused. I thought that a larger filter surface area would allow for better airflow for a longer period of time. I am using 1 inch pleated filters now but I have to change them very frequently.
    I understand that the static pressure would be restricted if I go with a higher MERV rating filter but would that be the case if I change from 1 inch to 4 inch all other things being equal?
    Honeywell makes 4" filters that fit into 1" frames.
    FC40R1094 12x12x4
    FC40R1037 12x24x4
    FC40R1078 24x24x4
    These would be MERV 10. You may need to have an additional return added to your system, depending on how well your returns were or were not sized.
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
