Results 1 to 13 of 17
    Austin, TX
    How often are you pulling evaporator heads on your Centrifugals??? (York YK's here)
    Happy "Friday Eve" e'rrrbody!
    So, I've noticed lately at my current employer, we're falling further behind on our chiller annuals, and as a result being forced to run inefficient machines as these spring cooling loads pick up...
    Annuals here consist of pulling both condenser and evaporator heads, brushing all tubes, borescope inspection of a few on each side, etc. Both sides are typically spotless. We have very clean chilled water on the evaporator side, with an abundance of side-stream filtration and impeccable water treatment. All chillers are either York YK or OM Titans.
    At my previous employer, we had the same fantastic water treatment, York YK's, and only pulled evaporator heads to brush/scope tubes every 3-5 years, also finding them to be pristine... and this despite having no side-stream CHW filtration there.
    I'm thinking of suggesting we move to a similar strategy at my current employer, with the obvious benefit of getting through annuals more quickly, and I'm curious what some of you guys have experienced with your annuals...
    Thanks!
    Jan 2015
    Somewhere making cold water
    Once every 3-5 years when we do eddy current test.
    Sent from my SM-G950U using Tapatalk
    Dec 2014
    New Mexico
    5-6 years depending on owners insurance underwriters, due eddy current at that time on both heat exchangers.
    Jun 2008
    Ohio
    Generally every five years
    ottawa canada
    Depends on how much money the customer wants to spend .
  6. Likes BALloyd liked this post
  7. #6
    Apr 2016
    Maryland
    Eddy Current is very important .
  8. #7
    Aug 2009
    Prattville, Alabama
    Assuming it's a closed chilled water system, I would follow York's recommendation on eddy current frequency and only pull the evaporator heads then. Unless I suspected problems, of course.
    In honor of RichardL: "Ain't 'None' of us as smart as 'All' of us".
  9. #8
    Jan 2015
    Iowa
    We recomment clean and eddy current on a 5 year cycle with good water qaulity.
    Question/comment. Your thought could be a two edged sword. If you are doing this for a customer your boss may not want to recommend this and give up that annual income. If this is for chillers your company owns there are no drawback just less maintenance cost. For the most part I base any extra cleaning recomendation on chiller performance, pressure, temps, amps, load changes, unexplained loss of refrigerant...... otherwise every 5 years
  10. #9
    Dec 2018
    Phoenix, AZ
    Some people do ECT every 3 years for CDW and every 6 for CHW. Some do 2 and 4. Some do 3 and 5.
    Sent from my LG-M327 using Tapatalk
  11. #10
    Dec 2018
    Condenser, Brush tubes annually and eddy current every 2-3 years
    Evaporator, Brush tubes and eddy current every 5 years.
    Once heavy wear or a problem is identified, eddy current is recommended every year
  12. #11
    Apr 2017
    The Deep South
    Quote Originally Posted by ChillerTech3384 View Post
    Very good advice here.
  13. #12
    Nov 2011
    East Side
    depends on water quality. we have 2 sites with horribly dirty chilled water loops...neither will spend the money on filtration. One site we had to brush the evaporator twice in a year, the other, we had to do last spring, and I'm going tomorrow to do it again.
    If you have good quality treatment and clean loops, what they said....
  14. #13
    Austin, TX
    Thanks everyone. Very good insight. We're almost to that time of year again, so hopefully, with all your input, this will get some traction.
