Results 1 to 8 of 8
    Jan 2017
    Navien NCB-240 BLEW!!!
    Came home to my Navien blr blowing city pressured water out of the cabinet. Shut water off and fnd that the water was coming from the cold domestic side inlet. Further investigation showed that a hole had been blown from a plastic cap located on top of the plastic inlet tee that connects to the flow sensor located in the boiler. Anyone ever seen this before or know what the cause was. Pretty unhappy that my first day with my newborn son was spent trying to get heat and hot water on in my hse. Also this issue ended up flooding my downstairs. Need some ammo before calling up Navien.
    Key info
    -blr under warranty still
    -blr Installed to manufactured specs
    -I get city water and it’s pretty clean up here in AK
    -did have pressure relieve on domestic side
    -water was static when blow (no one home when issue occurred)
    Jan 2017
    Do have photos if anyone knows how to upload them
    How many forum are you going to put this in? One should be sufficient.
    Jan 2017
    Enough to get an answer rather than a remark.
    Southold, NY
    Quote Originally Posted by BAMSTER04 View Post
    Let us know how it goes with the factory!
    Jan 2017
    Going to try and get ahold of the northwest rep first then go to the factory. Just wanted to see if anyone’s ever had this oddball issue with Navien or any other boilers using plastic fittings
    Mar 2010
    Rochester, NY
    Have you done any work to it lately?
    I had that happen after changing a flow sensor because a clip didn’t seat right.
    Jan 2017
    Replaced the 3-way diverting valve 5 months ago but no have not messed with the flow sensor or it’s assembly. It looks like a bullet hole went through that cap.
