Results 1 to 11 of 11
Thread: Replaced Cond Fan, can't cool below 10deg now
    Apr 2019
    Half ton system. Walk-in freezer, low temp. Only replaceed the evaporator motor - old motor would barely spin.. Then all of a sudden the system can't get below 10 degrees. We never cracked the system, or lost refrigerant. Checked the expansion valve and condenser coils. They look good, and are Distributing evenly. System Cycles well if set to 20 degrees. So this is more of a theory question - why would only replacing the fan change any of the Dynamics?
    Jun 2014
    Dover, DE
    Are you a professional service technician or are you the equipment owner?
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486 Instructor & Service Technician
    Southold, NY
    Define "Looks Good" that must be one of the things I've forgotten how to do!
    Southold, NY
    Apr 2019
    Yeah that's pretty sloppy. What I mean by that is the frost is evenly distributed and doesn't indicate that I need to make any adjustments. I usually use that is a go no-go indicator what's the weather or not expansion valve needs to be tweaked.
    Apr 2019
    Both
    Southold, NY
    What's the SH at the Outlet?
    What's the SH at the pump?
    SG Clear?
    Amps?
    Head Master?
    Head Pressure
    Receiver?
    Frost just means below freezing!
    Apr 2019
    I will check those tommrow and post, thx.
    Mar 2018
    Cottonwood, Ca #StateofJefferson
    Shine a flashlight thru the evap coil to see if its frozen up. Defrost schedule may not be able to overcome a dead evap motor
    Southold, NY
    Quote Originally Posted by SonRise View Post
    Update after 2 weeks!
    Southeastern Pa
    If you are a service tech, this is in the wrong area.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
