Results 1 to 12 of 12
Thread: Fiber board duct to metal equivalent questions
    Apr 2019
    Hi, first time post here. I'm trying to figure out if you measure the ID of the fiber duct to get the equivalent of metal ducting. If the fiber duct has an exterior of 8x18" and each side has approximately 1" of material that should equate to a 6x14" metal duct, right?
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by WillysJeep View Post
    6X16
    SE Ohio
    Quote Originally Posted by BNME8EZ View Post
    6X16
    Math show-off.
    Apr 2019
    Thank you. I'm trying to figure out this quote I'm looking at and that part just struck me as odd.
    Apr 2019
    6X16
    I did not know that there was a 6x16 available
    SE Ohio
    He was correcting your subtraction. 8x18 duct, subtract 2" from from each dimension becomes 8x16, not 8x14 as you stated in your first post.
    Duct can be fabricated in any size you specify for a metal shop.
    SE Ohio
    I even messed it up.
    Obviously it is 6x 14. Not 8x14.
    Apr 2019
    Quote Originally Posted by kdean1 View Post
    I figured as much. I did the post in a rush and wound up with a new math answer. I was trying to figure out if keeping the inside measurements of the existing fiber junk the same with new metal was kosher.
    SE Ohio
    The inside dimension is what determines how much air the duct can deliver. Outer insulation does not affect it but a duct liner on metal duct will. Duct board has a slightly higher friction rate compared to metal duct but a good contractor takes that into consideration.
    Aug 2009
    Beatrice, NE
    If I understand what you are saying it would depend on how much air you are trying to move through it. If replacing fiber with metal the metal should move slightly more air but if the fiber was not sized correctly in the first place the metal will be wrong also.
    Apr 2019
    That's why I was scratching my head. I figured there's bound to be calculations to be run, and maybe he did them and I didn't know, but it's bound to be more than a simple one to one swap. Cool.
    I'll hope the guy is on top of it. Thanks
    Jul 2009
    South Carolina
    Actually the 6x14 inside dimension would be the equivalent size for metal to a 6x16 inside ductboard dimension if you want the same friction rate.
    http://www.oceanhvac.com/ductulator/
    Gary
    The best things in life are free but not everyone is willing to pay the price.
    When you appreciate what you have, you have a lot more.
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
