Results 1 to 13 of 13
    Mar 2016
    Pahrump, NV
    Needle probes for iDVM 510 and 550?
    Jim B. or Bill S.
    What needle probes are available that work with the Redfish/Supco Multi-meters?
    Are there screw on tips, or complete lead sets?
    It's an upside down world we live in.
    Mar 2009
    Pittsburgh
    Quote Originally Posted by David Goodman View Post
    Jim B. or Bill S.
    See pic of what you get included.
    Are you looking for finer needle probes?
    Bill Spohn
    President & CEO
    www.TruTechTools.com
    Mar 2016
    Pahrump, NV
    Yes, I am looking for something even thinner than the tips that come with the 510 and the 550.
    Fluke 8845A-EFPT is an example.
    LG Multi V5 equipment has numerous plug connections on circuit boards with very small access openings for taking measurements. Standard probe tips are too thick to take measurements without distorting the plugs.
    I greatly appreciated that the 550 and 510 came with alligator clips, and that the 550 came with a line splitter.
    Another side note. The SupcoTechlink app for my iPad pulled up the manual for the meters in the “Helpful Resources” links, but on my Android phone it wouldn’t pull up the 550 manual.
    Yeap, needle probes are a must have on ton of equipment on the market now.
    Same issue for me on my Galaxy Note 5, just a white screen when I click the link for the 550in the Techlink app.
    It works fine in the MeasureQuick app though.
    SW Ohio
    Jim B. or Bill S.
    Like Fluke 8845A-EFPT Fieldpiece RCT2
    Just wanted to follow and bump back up top
    Mar 2016
    Pahrump, NV
    Quote Originally Posted by greg58 View Post
    The RTC2 tips appear to be uninsulated. Many of the test points are very close to each other. I can see inadvertently shorting the probes together.
    I would like only 4mm of the probe tip exposed.
    SW Ohio
    Mine have a heavy coating with only 1/4” exposed
    Mar 2016
    Pahrump, NV
    My Fieldpiece leads do seem to fit in the 510 and 550 even though they have a slightly different design.
    TruTech Tools does carry the RTC2 tips.
    I was hoping for confirmation that those leads and tips were compatible.
    Mar 2016
    Pahrump, NV
    Double post deleted.
    SW Ohio
    Sounds like we’re both looking for the same thing. Confirmation
    Jan 2002
    Chicago area, Il.
    I would look at Fluke leads, and think modular. Years ago, I bought a Fluke TK225 and L215 probe sets, that came with modular leads (banana connections on both ends) and a bunch of different probes, including needle probes that plug into the end of the leads. I dont know if these numbers are still good but they have taken care of al my testing needs for a long time.
    One other reason for the Fluke leads, they are longer than everyone elses.
    SW Ohio
    Fluke and Fldpc both work in 510. They are very slightly larger and was concerned over tme that the 510 probes would become too loose to work. No real big deal to me, I thought if they had needle probes I would get them.
    Fluke did seem to fit better than fldpc.
    Mar 2016
    Pahrump, NV
    Good to know.
