Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    Mar 2014
    Grand Blanc
    New Construction 2 Finished
    Finally able to get this job wrapped up. Just have to go back when the AC is wired up to test and balance the ductwork.
    Athens, Ohio
    That is a great looking installation!
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Mar 2010
    Rochester, NY
    Nice looking job... is the furnace staged? How are you managing the airflow when your smallest zone is on? Your sheet metal work looks great!
    Mar 2014
    Grand Blanc
    Quote Originally Posted by perfectionist View Post
    Thanks! Two stage furnace and two stage AC. Both zones are pretty large, smallest zone can handle 100% of the airflow.
    Mar 2010
    Rochester, NY
    In the past I have either used the carrier zone system with UI that works very well or I use a static press transducer with a external variable speed drive which also works well. Just an FYI I see you have an air gap on the furnace drain but the HPS is very finicky and can give you nuisance call backs, you might want to pipe the furnace drain separately to your termination FWIW.
    Jan 2014
    New England
    That's a beautiful clean install, I tend to place a piece of scrap sheetmetal under the service valves prior to brazing to prevent damaging on those particular type of condenser pads.
    Jun 2014
    Dover, DE
    Love it! My absolute favorite part is the intake and exhaust for the furnace come out the side and leave room to service the coil if needed.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486 Instructor & Service Technician
    Good job on the return and maximum filtration with least restriction putting the furnace up on the box. Also our techs would like the spacer between furnace & coil. They beg our installers to do that. Usually don't have the height. ADP coil?
    Oct 2011
    Gladstone, Oregon (Portland)
    I love that there are pdm linesets in all sizes now. Now they need to come up with a good pipe wrap or tape that matches it real well.
    Mar 2014
    Grand Blanc
    Thanks for looking out. I am very familiar with the code #31 issues with CBP. I have been installing Carrier/Payne for the past 6 years this drain set up works well.
    Mar 2014
    Grand Blanc
    Quote Originally Posted by Bazooka Joey View Post
    Yeah that would of been a good idea. Thanks for the future tip! Normally I wouldn't have that crappy of a fitting but I ordered the wrong line set and had to make a 7/8 to 3/4 fitting. Always a little difficult to fill in the joint.
    Mar 2014
    Grand Blanc
    Yeah supply house must of thought I was side job bob when I ordered Payne so it came with the ADP. I usually get the CNPVP coils. I liked that it was an A coil thought, less restrictive. Didn't like having to mount the sensing bulb.
    Mar 2015
    Hamersville, Ohio
    Jo,
    Is that Treated Lumber under the Condensing Unit?
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your Gods law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, I wasnt sent to anyone but the lost sheep of the house of Israel.
