Results 14 to 26 of 29
    Oct 2011
    Gladstone, Oregon (Portland)
    Quote Originally Posted by Snapperhead View Post
    indoor head/doorstop
    Ya. Figured one of you guys would say something about that. I had to match the existing hole because of crap on the other side of the wall. Being that the new unit is physically bigger it is what it is. That door is the entrance to the garage and still moves freely and the spring on it doesnt let it open enough to hit the unit anyway.
    Atlanta GA area
    WOW...
    Inverted rainbows...
    Grin
    GA-HVAC-Tech
    nice job only thing i would have done is bolt the feet to the wood blocks you used make it less tippy other then that nice work
    wow you drive upside down you must fly to your jobs
    Oct 2011
    Quote Originally Posted by pctech View Post
    It is bolted down. Cant see from the pic?
    Due to the distance from the unit its hard to tell but i trust your word so it works for me
    Oct 2011
    Ya. Hard to see as I was going to use some pretty beefy 3/8" head lags that I had initially. But if you are familiar with the feet on those condensors, there is a center hole that is large and 2 small ones left and right. I decided to not get too crazy and just installed 2" zips in each of the small holes, so it has eight 2" zips holding it down which is more than satisfactory per our inspectors.
    As an addition to this post. Whenever I install these units commercially, I use two 4 x 4 sleepers and then lay the pad on top with liquid nails. I then take 4" spikes with fender washers and make sure they go through the pad and bite into the sleepers at least an inch. Although sometimes that doesn't suffice for some of our inspectors as they want to see the entire setup anchored to the roof somehow. Becomes a pain as we have to locate structure below first of all, then have a roofer come out and "wrap" the sleepers to make everything water-tight.
    What I have been waiting to hear is just one thing:
    Is Adlerbert happy with his protege's installation?
    PHM
    Oct 2011
    Settle down. I think I told the story of where this stupid name came from.
    Virginia
    I didnt hear the story ....
    Mar 2013
    Treasure coast, FL
    You'd better settle down.
    Sent from my Moto Z (2) using Tapatalk
    Virginia
    I cant .... the coffee just kicked in ...
    Jan 2010
