Closed Thread
Results 1 to 10 of 10
Thread: pizza oven problem please help
    Mar 2019
    HI!
    I have a bakers pride pizza oven with the following problem
    The pilot goes out after 10 minute of operation
    I replaced the safety valve , thermostat and the thermocouple still having the same problem
    the safety valve was the old mercury one has been replaced with Robert Shawn ts11 valve the thermocouple is the heavy duty kind for pizza ovens
    What can be the problem when I lighted the pilot stays on turn thermostat to desired temperature usually 550 after ten minute or so the oven is off including the pilot what do you guys suggest me to check or replace again
    Thanks for your help
    Palumbogio
    Quick reply to this message Reply
    edmonds wa
    Not a DIY site . get a local service co to help you out.
    UA Local 32 retired as of Jan 2020
  4. Likes Dad liked this post.
  5. #4
    Mar 2019
    The oven been in the building for the past 18yr and no recent change
  6. #5
    Something has changed.
    I can't tell you how to fix your oven due to our site rules but usually when a TS-11 drops out the pilot goes out and cools the Tcouple.
    This said... what could cause the pilot light to go out? Your pilot flame is lifting away from the Tcouple as it looses it's secondary air around the burners.
    Call your local guy, he will know the difference in positive and negative air.
  7. #6
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    Where are you Gio ?
    Does the pilot flame wrap all the way around the thermocouple?
    PHM
    Quote Originally Posted by palumbogio View Post
    HI!
    Palumbogio
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  8. #7
    Mar 2019
    yes it does
  9. #8
    Jun 2013
    Have you set the new thermostat's bypass correctly? Main flame might be going out, then coming back on with a poof.
  10. #9
    Mar 2019
    what do you mean thermostat bypass and how do I do that
  11. #10
Closed Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
