Results 1 to 2 of 2
    Dec 2013
    1/3, 2/3 Head Pressure Control?
    I have a variable-primary flow chilled water plant that has 4 chillers using 1/3-2/3 modulating valves for condenser water head pressure control. Can anyone shed light on how the valves work together to maintain head pressure?
    Apr 2017
    The Deep South
    So, on an initial start command, the 1/3 valve will receive a call to open to minimum position. These are usually 0-10 or 2-10 VDC. Then based on head pressure, the valve will continue to open as the chiller puts heat into the condenser water. Usually around 40-50% signal, the 2/3 valve is enabled and then both valves will start opening. As tower water cools and head pressure drops, then the 2/3 valve closes first.
    Make sense?
