Results 1 to 13 of 21
    Oct 2011
    Chicagoland Area
    What to do with extra 5gal pails
    Make rigid duct
    Jan 2014
    New England
    I'm sure it will last longer and perform better than flex duct.
    Are the bottoms all cut out at least?
    Quote Originally Posted by 2sac View Post
    Make rigid duct
    PHM
    I did make a deep sump pump pit exactly that way though.
    PHM
    Oct 2014
    Columbus, Ohio
    Someone was really trying to get rid of some buckets. He could have done them in an alternating pattern and got away with about 4, but instead he decided to stack them together. Wow.
  6. Likes lions_lair liked this post
  7. #6
    what is this mess hooked up to what is its purpose
  8. #7
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by pctech View Post
    Not sure, I pulled the pic off the internet
  9. #8
    Oct 2011
    Gladstone, Oregon (Portland)
    I think back in the 50's and 60's people ate a bunch more pie. I have seen more pie plates blocking off old gravity furnace chimney holes than anything else.
  10. #9
    that and cardbord boxes and thin sheets of tin i have seen it all in my area
  11. #10
    Mar 2015
    Hamersville, Ohio
    Make rigid duct
    That is some fine "Innovation".
    What is the design static pressure, I'm wondering.
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  12. #11
    Mar 2015
    Hamersville, Ohio
    Yeppers, ... I've got a Customer, that has a sump pump in a crawl space, with about 12" deep of gravel, .... She had problems with the gravel getting in to her pumps, & when she called me, I found an empty 5 gallon bucket, dug a hole down in to the gravel, & put that bucket down so that it would hold back the gravel, & yet allow the water in to the bucket.
  13. #12
    Oct 2011
    I should show you guys my fix for frozen condensate lines. Need to patent it first.
  14. #13
    No; my sump pump pits are six-plus feet deep.
    I accidentally discovered that there is a thick layer of clay about 4-5 feet under my basement floor. Once I dug below that the pits became self draining.
    The stacked bucket idea didn't really work that well so I switched to a length of 20" black ribbed plastic culvert pipe.
    PHM
    Quote Originally Posted by DavidDeBord View Post
    PHM
