Thread: UniTrane Fan Coil A/C Unit Fan Speed Switch Retrofit
    Mar 2019
    Our building uses UniTrane Fan Coil units manufactured around 1968, all with a unit-mounted manual fan speed switch. Is there a conversion kit to replace the unit-mounted fan speed switch with a temperature sensor, either unit- or wall-mounted? Thank you!
    Southold, NY
    Im confused what the temperature sensor is going to do?
    The user adjusts the fan speed according to there needs
    Mar 2019
    turns out, the fan switch can be replaced with a line voltage fan coil thermostat, such as Honeywell TB6575B1000.
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
