Results 1 to 13 of 13
Thread: Goodman
    Caledonia WI
    Goodman
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
    Nice. Glad to see the 2 pipe installation. Also the box under the furnace so the entire 20x25 filter gets airflow. Nice return elbow.
    Mar 2014
    Grand Blanc
    I’m confused. What is the transition on the inside?
    Dec 2012
    columbus, OH
    Best return drops in the biz. I always put a brass cap on the txv equalizer port and a little leak lock. Guess the schrader gets burned up during installation and leaks. Its only about four inches from the suction line connection.
    Not sure its an issue with the uncased coils but definitely is with the airhandlers.
    Jan 2019
    Not a lot of install now days but on start up I being a 5/16 drill bit and pop holes for temperature difference keeps clean so other techs don’t bend flanges etc looking for gaps just cover with a cap
    Jan 2012
    Broomall, PA
    Excellent as always!
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Caledonia WI
    The coil opening is a bit small so instead of the air just running into a big flat surface it's funneled nicely into the coil.
    Quote Originally Posted by johoff34 View Post
  8. Likes Core_d liked this post
  9. #8
    Mar 2014
    Grand Blanc
    Quote Originally Posted by billg View Post
    Makes sense. So you were able to do that and not have any limit issues? With your ductwork I would be surprised if it doesn’t.
  10. #9
    Jan 2014
    New England
    Glad to see any brand off to a great start in life....providing all the start up guides commissioning of the system is followed...to manufacturers spec.
    Looks outstanding!
  11. #10
    Feb 2015
    Ohio
    Awesome work as always. I'm curious how that funnel works. Have you done this a lot or trying out something new? I hate finding undersized openings in coils. Happens a lot on older systems. Even worse is finding a sliver half the size of the coil opening cut by the prior installer. If this works well i'm definitely interested in trying it.
    "If common sense was so common, everyone would have it."
  12. #11
    Goes to show any brand can be a grate system IF the installer takes pride in his or her work like you have shown
  13. #12
    Caledonia WI
    I've been doing it forever with uncased coils, anytime you make a smooth transition it's going to help airflow.
  14. Likes johoff34 liked this post
  15. #13
    State College, PA
    That is awesome work and I can see the pride you have in your work by the final result.
    Now, how in the heck do you make that return drop do a wiggle like that?
    You make it look easy.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
