Results 1 to 9 of 9
    Mar 2019
    Cannot Find My Sight Glasses
    I am working on a Copelametic MRF2-0500-TFC (Serial 88C 78924) semi-hermetic that has a cracked sight glass. I need to get a replacement sight glass, but this compressor (circa 1988) does not use a newer three-bolt flange-mounted window but instead uses an older four-bolt flange that clamps onto a separate glass window and two O-rings front and back of the window. I cannot find just a glass window, without the fused metal flange, specifically for this compressor. I could pull out the cracked window and measure it to buy a window from a glass shop or to machine a metal plug, but the existing cracked window still seals with no leakage. I can't trust the window to remain sealed. Does anyone know the diameter and thickness of an old Copeland sight glass window (it looks about 1.75 in dia.) so I could order a glass shop replacement, before removal of the cracked window, to minimize downtime? Thanks.
    Southold, NY
    Any authorized Copeland Distributer will be able to order one.
    Is it leaking? Cant say I've ever seen one crack that's a thick piece of glass!
    Mar 2015
    Medford, N.Y.
    Didn't Copeland use the comp "dead eye" that was held in place by a threaded metal ring with two "slots" for a square metal "tool" for tightening/loosening the glass?
    May 2014
    Bay Area California
    Maybe I should post a photo of the custom sight glass removal tool I made decades ago. It's super sophisticated, not sure anyone here will be able to figure it out. Let me walk out to the garage . . .
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Mar 2015
    Medford, N.Y.
    I carry my tool on the truck,,,,,
    May 2014
    Bay Area California
    To remove a sight glass in something like a Copeland compressor, you need to get some good steel. Like from the rails on your bed frame.
    Or some one else's bed frame.
    Then grind it down like this:
    Quote Originally Posted by TechmanTerry View Post
    May 2014
    Bay Area California
    Yes, this is rocket science. LOL !!!
    Dec 2012
    columbus, OH
    Quote Originally Posted by BBeerme View Post
    Good thing you got that high tensile strength bed frame steel under you while your dreaming lol.
    Dec 2014
    I was in a bind once and ended up hack sawing an 1/8" or so from a gasket scraper. With its square shaft, it was easy to turn with a wrench. Had a beautiful translucent yellow handle too. Thats a while ago, now i have the socket for the job. Prob only used it twice in 5 years tho.
    Still have the gasket scraper.
    Sent from my SM-G950U using Tapatalk
