Page 1 of 4 1234 LastLast
Results 1 to 13 of 49
Thread: Three fuses
    Feb 2005
    Florida
    Three fuses
    What possible scenario could cause a loss of all three fuses? I replaced the fuses and found no problems.
    It was a 30 ton chiller with four compressors, the number one compressor in A stage was the one with the blown fuses.
    Aug 2013
    Single phase
  3. Likes CEAS-AC-TECH, Core_d liked this post
  4. #3
    Dec 2006
    phoenix
    Single phase could occur if one fuse blew, causing the other two fuses to draw high current, but it's not normal for both hot TD fuses to fail the same instant. 3 bad fuses is usually a ground. Did you megger the motor and check wiring, connections, etc? More common on 480 volt systems.
  5. Likes CEAS-AC-TECH liked this post
  6. #4
    Feb 2005
    Florida
    Quote Originally Posted by tunaguy View Post
    I have checked everything, and what's the odds that the two remaining time delay fuses blow at the time?
  7. #5
    Southeastern Pa
    If they're drawing too much current, the odds are very high.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. Likes lions_lair liked this post
  9. #6
    Southeastern Pa
    Of course anytime a fuse blows you want to be checking the fuse holder. If you're talking about an ancient disconnect, the fuse holders have probably lost their tension on the fuse end caps, and if so, the disconnect should be replaced.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  10. #7
    Feb 2005
    Florida
    Quote Originally Posted by timebuilder View Post
    How often have you seen three fuses blow, without a trace of why?
    This unit has a phase monitor, the Carel records events and also has Carel current sensors for each compressor.
  11. #8
    Southeastern Pa
    This can happen when the disconnect holders allow the fuses to overheat when the current is still normal.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. Likes lions_lair liked this post
  13. #9
    Feb 2005
    Florida
    No discoloration anyplace on any thing, I spent nearly two hours going over it. Fuses are very tight in the holders, put a megger on the compressor, starter is new, power cable to the compressor is new.
  14. #10
    Southeastern Pa
    Sounds like a pretty good mystery.
    It may not have a clear cause.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  15. #11
    Feb 2005
    Florida
    Fuses, maybe they came from Shenzhen.
  16. #12
    Virginia
    Never seen all 3 blow ... nope
  17. Likes The Turtleman liked this post
  18. #13
    Southeastern Pa
    Everything seems to come from there.....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
