Results 1 to 13 of 14
    Mar 2019
    High CFM per ton
    Curious running a system with 680CFM per ton (3400CFM on 5 Ton) with a constant full load (60,000BTUs) running a 80F with 60% humidity where everything runs great. The question I have is whether I run the system at 3400CFM or 2000CFM our latent and sensible loads "seem" to remain the same while maintaining the exact same conditions which should not be the case as per the math. Technically by dropping the CFM we should see a major bump in latent but our moisture removal stays consistent at roughly 18 pints per hour whether we drop the CFM or not. What am I missing?
    Southold, NY
    and who set this up?
    Dec 2012
    columbus, OH
    Is the system cycling? Keeping it at 80 it may not matter much. Is this a larger system with one compressor down or something? Give us an idea of the scenario here.
    New Mexico
    Not enough information. Major infiltration, faulty instruments, incorrect measuring methods, system unable to stabilize due to inconsistent loading.
    Problem I have is your saying they are the exact same conditions when we know that's doubtful. Not doubting you. It's just something might be overlooked.
    I might start with the 3400 cfm. How was that determined.
    Give me a relay with enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Madison, WI/Cape Coral, FL
    How are you determining the outputs and changes?
    Lowering air flow will decrease sensible cooling and increase latetent cooling plus decrease the total capacity of the system.
    Keep us posted.
    Regards Teddy Bear
  6. Likes Core_d liked this post
  7. #6
    Mar 2016
    Pahrump, NV
    What happens when you go from 2000 CFM to 1500 CFM?
    Did you check the inside of the cabinet for condensate blown off of the coil?
    It's an upside down world we live in.
  8. Likes Core_d liked this post
  9. #7
    Mar 2015
    Medford, N.Y.
    What is the advantage to the HIGHER CFM???
  10. #8
    Dec 2012
    columbus, OH
    Quote Originally Posted by TechmanTerry View Post
    Given the information in another current thread its possible the oversized blower acts as a load and extends the run times. We will have to hear from the op though. MrCfm
  11. #9
    Feb 2016
    Louisburg Kansas
    You got some good responses. The main question I have has already been ask but how are you measuring airflow?
    Thomas Jefferson
  12. #10
    Dec 2012
    columbus, OH
    Quote Originally Posted by WAYNE3298 View Post
    Its not a ecm blower with dip switches and lights that pushes 3400 cfm. I know that much.
  13. #11
    Higher cfm = warmer coil=more total cooling capacity=more sensible capacity= less latent capacity=t-stat statisfied quicker
    This is the most important part of setting up an a/c.
    Regards Teddy Bear
  14. #12
    Mar 2015
    Medford, N.Y.
    Hay,OP,where in the world are you? There is no "change" to the system/structure when going from 3400 CFM down to 2000CFM??
  15. #13
    Aug 2009
    Beatrice, NE
    I am interested in the equipment. I have never seen 5T equipment that will move 8.5 ton of air. If the charge was set with 3400 CFM then it can't be right at 2000.
Tags for this Thread
