Results 1 to 13 of 14
    Feb 2012
    IT rack in mechanical room
    Found this in a mechanical room next to a CW AHU with a puddle on the floor from a leaking CW valve. Oh yea, don't forget the water valve next to it
    Jan 2012
    Broomall, PA
    Free heat! First from the servers, then from the ensuing electrical fire.
    Uh...Google it yourself!
    Dec 2010
    WV
    Wow!!! Makes ya really wonder what some guys are thinking. Or those great engineers that spec it that way.
    kansas
    Hose bib acts as economizer
    Honeywell you can buy better but you cant pay more
    I told my wife when i die to sell my fishing stuff for what its worth not what i told her i paid for it
    Is no way i would allow that install in my building and i have done IT the water line moves or no rack is installed by my crew back in the day.
    Who ever wired that rack needs to go back to school what a jerry rigged mess
    that is not even the whole rack the back part is missing with the glass front and enclused back with the air filters somone did this job cheap
    Oct 2002
    Plano, TX
    Use to work high rise. Basement IT room was directly below 16 levels of public restrooms. You can guess what happened.
    Jan 2010
    Sea to Sky
    S#$t happened?
    Quote Originally Posted by timjimbob View Post
    Sent from my SM-G965W using Tapatalk
    Jan 2013
    Central Arkansas
    it the rack overheats that hose will be handy
    Feb 2012
    Quote Originally Posted by pctech View Post
    It gets worse :X pic coming soon lol
    But yea, this is one of several mechanical rooms with a similar set up..
    keep em comeing will use them for my IT classes on how NOT to install and wire a server rack
    Oct 2002
    Plano, TX
    Some of our transmitter site equipment has AHU directly above transmitters (big mistake #1) Several suites had emergency drains tied to common drain, that stopped up. Well, float switches don't do any good if adjacent AHUs continue running.
    Learn from this- Each AHU should have seperate drain and never tied to a common line. I think this is not addressed in IMC but should be.
    Jun 2012
    Northern NV
    It looks like someone may have hacked in the hose bibb after the fact. That would not surprise me either......
    Looks to be PEX and a bit far from the wall for original to the structure, but a handy distance of the centerline of the hammerdrill......
