Results 1 to 8 of 8
    Mar 2019
    Sanra Clara
    Tips for dealing with litter box smell?
    Hey, so despite my best efforts, my kitty's litter is starting to stink up the apartment. I had been leaving a window open in the litter-box room earlier, but now it's either too cold or too rainy to do that (the rain comes right in the window). The brand of litter I'm using claims to be odor absorbent, but it's really not enough. Anyone have suggestions of air fresheners or other things I can use to improve the situation?
    Dec 2006
    Vancouver, B.C.
    I installed a high CFM bathroom exhaust fan and run that in the room 24/7. If you do that then get a quiet one.
    Frequent litter box changes, ours is scooped daily and changed weekly.
    We use the crystals (kinda like silica moisture absorbent, if that’s or exactly what it is) and it seems to do a good job.
    Quickly, I must hurry, for there go my people and I am their leader!
    Jul 2010
    US of A
    Might want to try using wood pellets for a pellet stove as litter. 5-6 dollars for a 40lb bag also. Clean it every day and you shouldn't have a problem.
    I would be hesitant to advise someone to run a high cfm fan in the bathroom 24-7 without seeing their heater and water heater setup.
    Signature removed Violated rule #15
    Jun 2012
    Northern NV
    Friend of mine taught the cat to use their toilet. They had to flush for the cat, but no handling bio-hazard and breathing cat piss stench.....
    Dec 2006
    Vancouver, B.C.
    Quote Originally Posted by pageyjim View Post
    That’s a fair concern, an ERV might be a better solution but it’s still going to have an effect on the overall capacity requirements of the system. My point was more towards getting the space in a slightly negative pressure so the smells don’t drift through the house. If the resident is unfamiliar with HVAC then they should consult a professional to help them design a solution that will keep the space comfortable if they are concerned about that, and avoid creating a negative draft situation if they have gas burning appliances.
    Jul 2018
    Wisconsin
    Leave the door open.
    Feb 2019
    Electrostatic Air Purifier will help you.
    Apr 2019
    Leave the door open or else take the help of the professional.
