Results 1 to 13 of 23
    Feb 2018
    Bay Area, Ca
    High efficiency venting options.
    My boss sold this job that has 2 furnaces. Furnace 1 is being replaced with a Bryant evolution 95%. Furnace 2 is staying. We are below grade with the old 80% venting into a chimney. We have another chimney right next to it available but it offsets about 10" and I cant get 3" PVC in that offset. Any ideas?
    I have heard of poly vents but no one around here knows WTF I'm asking for.
    Sent from my SM-G955U using Tapatalk
    Jul 2018
    Wisconsin
    Will 2inch fit? If so you may be able to reduce to 2inch for a short length. It shouldn't restrict a crazy amount but will increase the velocity in that section of pipe. If you need to reduce on a horizontal keep in mind you can get eccentric PVC reducers.
  3. Likes Zamoramax liked this post
  4. #3
    Feb 2018
    Bay Area, Ca
    Quote Originally Posted by Spitz View Post
    Not really. Its 7x7 terracotta and it offsets about 12 inches over 3 ft.
  5. #4
    Apr 2003
    Maple Grove, MN
    This might be the "poly vent" that you heard about. I have never seen or used it, but it might be a good option if you can find someone to sell you the stuff.....
    http://www.duravent.com/Product.aspx?hProduct=26
    If at First You Don't Succeed, Skydiving Is Not for You.
  6. Likes Zamoramax liked this post
  7. #5
    Jul 2000
    Northern Wisconsin
    If the other chimney is straight, swap furnace venting?
  8. Likes Zamoramax liked this post
  9. #6
    Jul 2018
    Wisconsin
    Quote Originally Posted by firecontrol View Post
    Was thinking sell them two new furnaces and run the pvc up the chimney
  10. #7
    Feb 2018
    Bay Area, Ca
    I have been thinking about this for about an hour now.
  11. #8
    Sep 2015
    Ontari-ari-ari-o
    How far below grade? I consider running venting up and out the chimney the last resort usually there is some spot to punch a hole and take the venting out the side. If I have to break out any ladder taller than 6' that is a failure of a day to me.
  12. #9
    Feb 2018
    Bay Area, Ca
    Quote Originally Posted by ammoniadog View Post
    That's the stuff just gotta find it.
  13. #10
    Feb 2018
    Bay Area, Ca
    Quote Originally Posted by Sooty View Post
    The subfloor above is at grade. My only option. Is up and I'm beginning to think swapping the flue is the answer.
  14. #11
    Sep 2015
    Ontari-ari-ari-o
    Could you get where you need to go with a helper and a shovel?
  15. Likes Zamoramax liked this post
  16. #12
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by Zamoramax View Post
    "We are below grade"
    Meaning that the Banding board for the Floor joists is "Below Grade" Zamoramax?
    Can't You Sidewall the Venting via Sch. 40 PVC?
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  17. Likes Zamoramax liked this post
  18. #13
    Mar 2015
    Hamersville, Ohio
