    Nov 2009
    ontario,can
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hobart lxeh passwords
    Does anybody known the soap and service passwords for this machine ? Thanks
    Nov 2013
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by fixit52 View Post
    8934
    Nov 2009
    ontario,can
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dakota11 View Post
    8934
    thanks im trying to prime the sanitizer pump. can that be done in the soap or service menu and does this password get you into both? the display is showing no sanitzer. the pump runs during the cycle but does not pump chemical. i have ordered a new service kit for the pump. just wondered if there was a way to force the pump to run to speed up the priming.
    Nov 2013
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That number gives u access to all functions......there is a separate number for just soap but u don't need it.
    Your saying it shows no detergent ? or sanitizer ? You don't need chlorine on unit with a booster, so u can disable that one if im understanding what u mean.
    Yes u can prime pumps in the settings , u will see it.
    Most likely your problem is the squeeze tube has flatten out part number 949651-1
    Nov 2009
    ontario,can
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I meant rinse aid sorry. And j have ordered the pinch tube . Thanks so much
    Sent from my SM-A520W using Tapatalk
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
