Results 27 to 39 of 52
  1. #27
    Jan 2001
    Carlisle, Pa
    Quote Originally Posted by hvac17011 View Post
    Mark,
    Do you use fieldpiece all the time as in svc calls charging etc. Not just when someone wants a report. Been thinking of going wireless
    What exactly do you use to add charge just an access tee??
  2. #28
    Chicago area
    Something like this.
    Female to the system, one male to the gauge, and 1 to the refer tank
  3. #29
    Yes, and I use the thumb screw style core depressors to connect to a system to reduce refrigerant loss to the minimum possible.
  4. #30
    Quote Originally Posted by Core_d View Post
    Reminder to anyone i have the high and low pressure transducers for sale and also a couple of a manifolds.....
    AK’s?
    Heating/Cooling Services Inc.
    www.heatingandcoolingservicesinc.com
  6. #32
    VA
    It all fits neatly in the case that comes with the JL3 kit.
    I’m using the low loss 90° adapters from Yellow Jacket, but high pressure and the large size of the fitting sometimes makes it difficult to screw on.
    I’m liking the thumb screw style. What brand are those. I saw some bad reviews on the C&D.
    I hope the seals are more reliable.
    "The only true wisdom is in knowing you know nothing" Socrates
  7. #33
    Quote Originally Posted by mgenius33 View Post
    The C&D ones are garbage.
    I get the core depressors on ebay, the seals are PTFE and stay in, unlike the unsecured o-ring in the C&D ones.
    They also fully back seat if you back off the thumb screw enough.
    https://www.ebay.com/sch/i.html?_fro...LH_TitleDesc=0
    AccuTools has one, but I've no idea what kind of seal it has, or if it back seats. They look shorter than the ones I have, so I may order a couple from TTT to try out.
    https://www.trutechtools.com/Accutoo...r-Tool-1-4x1-4
    I also keep a couple of 90º low loss fittings for connecting to service ports in tight areas.
  8. #34
    Jan 2001
    Carlisle, Pa
    Do you just have the standard 2 pressure probes,2 air probes 2 clamps or do you keep more on hand
  9. #35
    Dec 2012
    columbus, OH
    AK’s?
    Yes sir for the aks, asking $60+shipping
  10. #36
    I have an extra air probe for outdoor temperature, and will likely order an extra temperature clamp for discharge line temperatures and an extra pressure probe as a spare this week.
    Too bad my Sporlane probes won't work with MQ, or I'd already have spares.
  11. #37
    VA
    Thanks, I saw the bad reviews on the C&D's just before I ordered them, so I stopped.
    I just ordered a pair of the eBay ones you linked.
  12. #38
    Thoughts on Bluetooth gauges
    Say what? Just the sensors or an entire manifold for $60? Post pics of what you’re talking about. I’d feel like I was straight up Compton robbing you if I only paid sixty for an AK900
  13. #39
    The drawback is that it will likely be 2-4 weeks before you get them.
