Next level mama
The problem is the bucket is upside down.
Post Likes - 1 Likes, 0 Dislikes
Originally Posted by
firecontrol
Yeah but the union to disconnect the drain to get the container out is mint
Post Likes - 2 Likes, 0 Dislikes
The condensate pump being put into a larger container I've done before. We have a lot of vacation homes here with septic systems that have shallow buried sewer lines leading from the home to the tank. When there is no discharge going down that line all winter long except for the tiny amount of condensate from a furnace the pipe will freeze solid. We sit the condensate pump in a large tote and drill holes in the condensate pump's tank (and sit a brick on top of the housing) to greatly increase the amount of discharge to the sewer. Instead of a quart being pumped, when the float activates it will discharge a few gallons per run making it a lot less likely to freeze the sewer line. We even do this in homes where there is a gravity drain the furnace "could" go into without the need for a pump.
I don't ever remember adding a six pack plastic and .......... what looks to be a pair of tighty-whities in the tub.
This was my fix
Same pump by the way
Did I miss is...
Looked like the flue pipe on the old 80%-er... was open in the room???
Good looking install!
GA-HVAC-Tech
GA's basic rules of home heating and AC upgrades:
*Installation is more important than the brand of equipment
*The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
*The value of comfort, over the long term; leave economic choices behind!
Choose your contractor wisely!
ga-hvac-tech
Did I miss is...
The metal is just dark
Damn carrier/bryant doors always misaligned, flimsy cabinets and latches that "sorta kinda" hold the door on. Couldn't they just stamp a few patterns into the sheet metal to make it a little stiffer?
There was a water heater next to the RA drop before the fix, did you move the WH?
Those who dance, appear insane to those who do not hear the music.
Those who believe, appear ignorant to those who do not know God.
cehs
Yes. They went outdoor tankless
Shes a Leaker MOMMA shes a LEAKER MOMMA he is a good guy for the most part steve lav that is
why no intake air from out side like we have to do in my area?
pctech
It’s in a garage.
you have it good in certain towns in my state it has to be from the out side no matter what its a pain
In GA (state)...
The determining factor is the volume of air in the room the furnace is in...
See the stuff in the IOM manual.
If there is enough volume of air to support combustion... then no outside combustion air is needed.
Personal opinion (supported by NCI): combustion air is COLD... this lowers peak combustion temperature... thus lowering fuel efficiency.
So WHY use outdoor air???
Now up north... the answer is: because the combustion air has to come into the house from somewhere...
And that air is infiltration... which cools the heated air in the house.
Down here in the South... while that still happens... our lows are not that low (most of the time)...
So it is not as serious an issue.
We do not use outdoor combustion air unless it is necessary.
GA-HVAC-Tech
with the cold and snow you get i can understand why
