Results 1 to 13 of 17
Thread: Next level mama
    Feb 2011
    Georgia
    Next level mama
    Jul 2000
    Northern Wisconsin
    The problem is the bucket is upside down.
  3. Likes chrisevansac liked this post
  4. #3
    Aug 2015
    Buffalo,NY
    Quote Originally Posted by firecontrol View Post
    Yeah but the union to disconnect the drain to get the container out is mint
  5. Likes chrisevansac, Zamoramax liked this post
  6. #4
    Jul 2000
    Northern Wisconsin
    The condensate pump being put into a larger container I've done before. We have a lot of vacation homes here with septic systems that have shallow buried sewer lines leading from the home to the tank. When there is no discharge going down that line all winter long except for the tiny amount of condensate from a furnace the pipe will freeze solid. We sit the condensate pump in a large tote and drill holes in the condensate pump's tank (and sit a brick on top of the housing) to greatly increase the amount of discharge to the sewer. Instead of a quart being pumped, when the float activates it will discharge a few gallons per run making it a lot less likely to freeze the sewer line. We even do this in homes where there is a gravity drain the furnace "could" go into without the need for a pump.
    I don't ever remember adding a six pack plastic and .......... what looks to be a pair of tighty-whities in the tub.
  7. Likes chrisevansac liked this post
  8. #5
    Feb 2011
    Georgia
    This was my fix
  9. #6
    Feb 2011
    Georgia
    Same pump by the way
  10. #7
    Atlanta GA area
    Did I miss is...
    Looked like the flue pipe on the old 80%-er... was open in the room???
    Good looking install!
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
  11. Likes chrisevansac liked this post
  12. #8
    Feb 2011
    Georgia
    Quote Originally Posted by ga-hvac-tech View Post
    Did I miss is...
    The metal is just dark
  13. #9
    Oct 2014
    Columbus, Ohio
    Damn carrier/bryant doors always misaligned, flimsy cabinets and latches that "sorta kinda" hold the door on. Couldn't they just stamp a few patterns into the sheet metal to make it a little stiffer?
  14. Likes chrisevansac liked this post
  15. #10
    Urbandale IA. USA
    There was a water heater next to the RA drop before the fix, did you move the WH?
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
  16. Likes chrisevansac liked this post
  17. #11
    Feb 2011
    Georgia
    Quote Originally Posted by cehs View Post
    Yes. They went outdoor tankless
  18. #12
    Shes a Leaker MOMMA shes a LEAKER MOMMA he is a good guy for the most part steve lav that is
  19. Likes chrisevansac liked this post
  20. #13
    why no intake air from out side like we have to do in my area?
