Results 1 to 20 of 34
Thread: hoshizaki ice machine
    Aug 2009
    Rhode Island
    Anyoe ever have any luck with silicon spray if ice isnt always falling off properly
    Southold, NY
    Quote Originally Posted by camp175 View Post
    Probably the evaporators shot!
  3. Likes bacciagalupe liked this post.
  4. #3
    Pearland Texas
    Hoshizakis use water to assist during harvest. I have seen where they get enough water to make ice but not enough to harvest ice. The water filters were stopped up just enough to keep it from harvesting. Changed water filters and everything worked.
  5. #4
    Jan 2010
    Well it's not from loss of nickel plate.
    What's the hot gas like ?
  6. #5
    Oct 2011
    Chicagoland Area
    I'd start with giving it a thorough cleaning
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  7. #6
    Jun 2006
    I use WD40....
  8. #7
    Aug 2001
    After cleaning with Hoshi cleaner with long handle brush following directions. Verify water supply and extend harvest time on board. Verify water flow by checking time it takes to overfill sump at startup.
  9. #8
    Nov 2001
    East Texas
    No
    TACLB16522C
  10. #9
    Virginia
    there are micro switches on board , you can make harvest longer
  11. #10
    Northern Indiana
    that can’t actually be someone’s option of getting ice to release. Are we talking like a food grade silicone spray? Or are we just spraying whatever we have rattling around in the old war wagon.
    Have run into many problems with improper water flow issues. Or just a dirty machine. Need a lot more information to correctly remedy the problem. And I would never use silicone to get ice to drop.
    Maybe try PAM.
    Sorry couldn’t resist.
    _____________________________
    PHMTECK
  12. #11
    Southold, NY
    Quote Originally Posted by Snapperhead View Post
    On Hoshizaki?
  13. #12
    At The Point Of No Return
    On Hoshizaki?
    Yes been there for years and years. We call them dip switches.
  14. #13
    Southold, NY
    I’m thinking Ice o mystic!
  15. #14
    Apr 2010
    California
    Just Say No, to all of the "bandaid release agents", such as pam, silicone etc. What is the model number please?
  16. #15
    Dec 2009
    maroon lazyboy
    Did they spray with a side-to-side motion keeping the can 6-10” away from the grid? If so, nope still not a good idea
  17. #16
    Quote Originally Posted by Phmteck View Post
    Maybe try PAM.
    X2 and X3
    We use the special food grade butter round hereya. Never ever margerine though. That would be bad.
  18. #17
    Seriously though lack of water flow a1 culprit for ice clog between plates especially on hoshis
  19. #18
    Oct 2009
    Atlanta,Ga.
    Silicone spray will work, if the evaporator is not too bad.First make sure the evaporator is clean, good water flow, proper harvest, proper freon charge.It takes more freon to harvest, than to make ice.Freon charge must be correct.If the machine is clean and operating properly, but the plates are worn, spray will help, but you will have to spray it every few days.,It is a temporary fix!!!Fix the real problem!!!If plates are real worn .spray won't help.
  20. #19
    Southold, NY
    Quote Originally Posted by Dan_b View Post
    Good information
    Truth Hurts!
  21. #20
    Jun 2019
    Hoshizaki is a global leader in the design, manufacturing, and marketing of equipment for the foodservice industry, including: Ice Machines & Refrigeration.
