Results 1 to 13 of 14
    Aug 2009
    Rhode Island
    water in carrier inducer
    ive seen this twice and dont really know why on 2 seperate condensing carrier furnaces model 59SP5A100 the draft inducer fills with water. All drains are clear i can watch it drain, vent is correct size and pitched correctly, furnaces are level, all tubes connected properly. just wondering if anyone else has seen this?
    Aug 2013
    Visalia California 93291
    Condensate trap Orientation/installation correct/functional ?
    Virginia
    Quote Originally Posted by camp175 View Post
    Is the pressure switch tripping?
    Dec 2013
    Grand Junction Colorado
    Too long of uninsulated PVC venting in the unconditioned Attic?
    Sent from my Pixel 2 XL using Tapatalk
    Dec 2013
    Not that I don't think that the furnace should be able to handle the excess condensate drain back but that is what happened when I had the same issue on a Goodman furnace
    Nov 2014
    Portland, Oregon, United States
    I can tell you, but not in an unlocked area of the forum.
    Sent from my SM-N950U using Tapatalk
    Dec 2018
    Erie, Pa
    I've run into the same problem and never really found a cause, I'm assuming it's building up somehow and flooding down into there after it shuts down. It would only happen every few days, so I'm Unsure.
    Nov 2014
    Apply for pro membership. It is an issue, and if you want the info I can delve into it. It is a head scratcher, and the only reason I am versed in it, is because it kicked my tail a few times.
    Aug 2009
    Rhode Island
    they are both vertical
    Aug 2009
    Rhode Island
    one is in a basement one is in bottom floor of a raised ranch
    Jul 2014
    Had it happen to me a few times. It is a easy fix.
    Dec 2013
    Quote Originally Posted by technocratic View Post
    Well I have a pro membership can you tell me? Lol
    Aug 2013
    Quote Originally Posted by gladiatormaniac View Post
    In a closed forum, repost or ask mods to move
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
