+ Reply to Thread
Results 21 to 28 of 28
Thread: Ice on the ceiling of a walk in
  1. #21
    Jun 2006
    Quote Originally Posted by rider77 View Post
    Ever wonder why freezers have heated vents? It’s to avoid drawing a negative pressure on the box when the door is opened and warm air rushes in, then is quickly cooled and thus takes up less volume. Freezers tend to be their own little low pressure zones if you will.
    At an extreme case, I had a box located outdoors that had an untrapped drain. It would pull humidity in so bad it would build ice on the fan guards and either freeze the blades in place or break them altogether.
    Seen WIFs that the door could not be opened until the air pressures equalized.
    We normally put a delay timer on the fans connected to the door in that case.
    I am familiar with heated vents.
  2. #22
    Jun 2006
    n.texas
    Thumbs up
    Quote Originally Posted by stat View Post
    I have heard this for 30 years. Worked on many WIF without trapped drains. Never seen it cause an issue.
    That's just me though. YMMV.
  3. #23
    Feb 2019
    Mississippi
    It would be nice if the users listen to us techs because shutting units off at disconnect is wear and tear on units
  4. #24
    Oct 2009
    Atlanta,Ga.
    Make sure the X wire takes the unit out of defrost ,before the heaters get hot enough to form steam.the steam will get on the ceiling,Drip on the floor.create ice on the ceiling and floor.Make sure the coil is good and frosted before the fans come back on.I have had to add separate defrost thermostats to get the coil to frost enough and not blow water off the coil.
  5. #25
    Apr 2004
    Waterloo N.Y.
    How's this beauty. Stat set to -25, fan delay not working and they prop the door all the time. There is a steam kettle about 6 feet away from the door!
    There's TREACHERY AFOOT!!!
  6. #26
    Apr 2018
    Rhode Island
    Quote Originally Posted by mcr View Post
    At least the ceiling is now fully insulated.
  7. #27
    kansas
    Last time I seen stuff like that drugs were involved
  8. #28
    British Columbia, Canada
    Defrost Termination Fan Delay switch not working properly. Coil has to freeze the moisture onto the fins before the evap fan(s) start(s). This is to eliminate blowoff of moisture into the box which will accumulate on the ceiling and other surfaces.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
