Results 14 to 23 of 23
    Jan 2010
    I guess a model number is out of the question....
    Apr 2005
    Australia : Queensland
    Quote Originally Posted by icemeister View Post
    Get this...
    ...and one of these:
    X2
    Haha , 2 of the most basic tools. They are priceless.
    Most manufactures won’t tell you their design specs so the above is the preferred method.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
    Apr 2005
    He removed it and set it somewhere and now can't remember where he set it.
    Happens to me all the time.
    I usually retrace my steps when this happens ,,, you could try that.
    Jul 2000
    Guayaquil, EC
    The LG info you posted indicates the NR58LAJG has a capacity with R134A of 607 Btuh at -10 Deg F SST at 60 hz. Using the Tecumseh cap tube selection I entered this capacity with 120 Deg F SCT, 36" heat exchange length and .026" ID cap tube. The calculated length of 88".
    I selected .026" ID simply because it results in a good length...not too short and not too long. If you want to size for a different ID just enter what I did and run it with the ID you want.
    Jun 2018
    OK sir.. will try practical also.. thx..
    Some one said me that we can pressure check the capillary tube by giving pressure of approximately 250 psi by using external compressor is it true ?
    Supco- bullet tube chart just need gas and comp hp
    Mar 2015
    Medford, N.Y.
    I just scrapped an old captube at the junk yard and I got 1 penny for it. I can't remember where I got it from,but,it came from somewhere.What did your captube look like? I hope it wasn't yours!
    Quote Originally Posted by techntech View Post
    Sounds too high for 134
    It would work well if you knew what a working one did
    Apr 2005
    I think your at the point where you need to by a new fridge. Labour on this job alone outweighs the cost of replacement , especially if you are still trying to find the lost restrictor.
