Results 1 to 4 of 4
    May 2014
    FX-Jace Numeric writeable not accepting commands
    Having issues with some setpoints in a PCV-1630 not allowing setpoint changes to the points mapped into the FX-Jace running 4.2 software. The points are under the Balancer Override SD primitive in PCT. The mapped points are CLG-MAXFLOW, CLGOCC-MINFLOW, HTGOCC-MINFLOW, SA-AREA, and SA-KFACTOR. They are mapped as Numeric writeable, but turn orange when commanded and show as not writeable.
    Any help with this issue would be greatly appreciated.
    Connecticut
    It sounds like they are not set up as Network Inputs in the PCV. In the Jace, instead of writing to Present Value on the numeric writeable, change the attribute to 3113 and see if it writes then.
  3. Likes bolt950rider liked this post.
  4. #3
    May 2014
    Thank you. Using 3113 worked great! Have to change the point to writeable first then enter 3113 on top of the present value box.
  5. #4
    Mar 2018
    That should be writing to the relinquish default value, either you can look through the drop down menu of the points properties, or when you discover points, hit the +next to a point and grab the relinquish default point/match it to the one you brought in already.
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
