+ Reply to Thread
Results 21 to 40 of 40
Thread: 90 % gas furnace
  1. #21
    Dec 2014
    5 words. One emoji
    Combustion analysis.
    Post your numbers.
    Sent from my SM-G950U using Tapatalk
  2. #22
    Quote Originally Posted by rundawg View Post
    Were you able to verify that model number?
    Maybe TUX1D120
    I got 60 or 70 feet of 3".
    No manual on site?
  3. #23
    Virginia
    Quote Originally Posted by pacnw View Post
    Maybe TUX1D120
    No manual on site?
    That must be the model number.
    If so, I get 60 feet max before you even add any 90º's or 45º's.
    Side note: I accidentally email you the manual, which I think you already have.
  4. #24
    Aug 2009
    Beatrice, NE
    Just to recap we have a 92% furnace with twice as much vent length as listed max, no pressure readings, no CA readings, and a 20 year tech.
    My diagnosis . . . it's broke.
  5. #25
    Southold, NY
    Quote Originally Posted by BNME8EZ View Post
    Lets change This, maybe That, get on your phone...……..for what the manual, No answers!!!
  6. #26
    Dec 2006
    tyler tx
    Thanks for all the answers, all good answers and some already been done, it defently starving for air when all connect, when fresh air is disconnect all reading are good. When fresh air is reconnected all falls apart . Going to take heat exchanger apart
    It work fine for years started this pass fall
  7. #27
    Quote Originally Posted by 86project View Post
    Parts changer, not a technician!!!
    You have been given the reason, but refuse to believe it.
    I'm out.
  8. #28
    Southold, NY
    Unbelievable!
  9. #29
    Mar 2015
    Hamersville, Ohio
    :eek2
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  10. #30
    Mar 2015
    Hamersville, Ohio
    86, can You define "All reading are good", when the "fresh air is disconnect"?
    Am I misunderstanding, or, .... Are You saying that this furnace is operating per the Manufacturer's Specifications, when You have the Combustion Air Pipe disconnected prior to it entering this furnace?
  11. #31
    Southold, NY
    Quote Originally Posted by DavidDeBord View Post
    Let him have fun checking the exchanger, changing it THEN coming back here
  12. #32
    Aug 2009
    Beatrice, NE
    I'm trying to figure out, I have never had a test instrument that would give "good" as a reading. It was always in numbers. I may need to look into updating my tools.
  13. Likes icy78 liked this post.
  14. #33
    Southold, NY
    You do have one that states “Retard” just saying!
  15. #34
    Mar 2015
    Hamersville, Ohio
    Could this be "The Kux" or whatever his name was, under a different Name?
  16. #35
    Mar 2015
    Hamersville, Ohio
  17. #36
    Jul 2018
    Wisconsin
    Supco megger. Good, Caution, Bad....lol
  18. #37
    Dec 2006
    tyler tx
    Thanks for the help, with all the help I am looking at too much length of flue pipe. Look over manual it all points to flue. now why it has worked for fine all the years I can not understand. but i just started working on this unit last fall and i have no history. thank you again
  19. #38
    Mar 2015
    Hamersville, Ohio
    Actually 86,...
    Your Profile doesn't show that You are a Tech, or a Installer.
    You are in a Situation, Far over your Head, that could cause harm to life & /or property, if not Properly handled.
    Put the Tools Down, ... Back slowly away from this furnace, & Call in someone that is Experienced & Qualified.
  20. #39
    Southold, NY
    How has it worked? Probably just on the edge. now a little older and it wont!
    Bottom line the IOM States 60' Max your at 100. Shorten the vent, Maybe increase the size but follow the IOM first!
  21. #40
    Dec 2014
    Possible the installer adjusted the .....(cant say here) to make them work. That wouldve been a bad move if it was done.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
