Page 4 of 4 FirstFirst 1234
Results 40 to 50 of 50
  1. #40
    Aug 2010
    Living rent free
    Dam I bet that took a few minutes to figure out
    Lol.. but I still remember the customers name, street, and I could probably pick out the house. What we call, a lasting impression.
    "If you can’t describe what you are doing as a process, you don’t know what you are doing." ~ W. Edwards Deming
    All those who wander..are not lost.
    Do NOT..mistake my kindness for weakness.
    The early bird may get the worm..but the second mouse gets the cheese.
  2. #41
    Quote Originally Posted by Lickety-Split View Post
    And how should I begin looking for the 24 volts without any of these wires connected to the terminal block on this RTU?
    Since the contactors go on and off erratically, its probly gonna be hard to find. I would remove 3 ph power from Compressor , then crank up unit ( hoping the fans would come on ) and begin wiggling , and unhooking stuff on low volt wires until the fans quit
    It might even be the 'board' causing the strange stuff
    Look on the back of board for spider web or something funky...
  3. #42
    Southeastern Pa
    If you eliminate damage or some other issue with the wiring from the board to the contactors, the reason could be the board itself.
    Make sure that all of the connections to the board that are intentional grounds (used to power board logic) are solidly connected. If the board does not have a continuous 24 volt common for its on board DC power supply, you can get all kinds of crazy activity.
    Study the schematic to look for all of those connections, and make sure they are 100% good.
    An example of this is the Carrier gas pack board. If you were to look closely at the lower right hand corner, there is a black square around the metal standoff that tells you there MUST be a ground screw there. It is the one screw that Carrier says cannot be left out.
    Check those connections before condemning the board.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  4. #43
    Jan 2019
    No board,just a whole lot of relays
  5. #44
    Jan 2019
    They have these gas reheat relays for dehumidification.
    So with this cold weather...Im gonna have to check the crankcase heater. This could have taken out the compressor.
    Come to find out...it can run AC in the winter for dehumidification,then it will heat.
  6. #45
    Southeastern Pa
    Commander James Montgomery Scott:
    https://www.youtube.com/watch?v=T2NsTi_43g4
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  7. #46
    Jan 2019
    Ha! True that
  8. #47
    Southold, NY
    Jan 2019
    Thanks! Good stuff!
  10. #49
    Jan 2019
    And by the way...I want to openly apologize for unrighfully accusing you of being a jerk in front of all that are reading this. I was wrong and feel stupid for trusting some cheap needle-like leads...against a professional like yourself. I have had a lot of things going on and was stressed. I feel bad and apologize!
  11. Likes lions_lair, beenthere, icy78 liked this post
  12. #50
    Southold, NY
