Results 1 to 13 of 19
    Dec 2018
    Ventura, CA
    Carrier variable speed furnace
    Did a call out on a Carrier 58MVP variable speed 2 stage furnace. Blower motor not coming on during call for heat or fan only. code 44 comes up.
    Not sure how to determine if motor is bad or the main board. Hoping to get some feedback.
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by HVAC_Marc View Post
    I havent installed many VS furnaces but the ones that Ive had never had a chirp noise at startup. There was always a dull thump-thump when the fan motor determined correct rotation direction, but that's it.
    I'm guessing this was for a different thread?
    Quote Originally Posted by navyguy1 View Post
    Does a Code 12 pop up shortly after a Code 44?
    I emailed you some info that may help you troubleshoot this issue.
    Side note - get that post count to 15 and apply for PRO membership so we can discuss theses issues in more detail inside the "LOCKED" Pro forums.
    Mar 2013
    Quote Originally Posted by rundawg View Post
    you're correct. I never opened this post until now. When I posted it was on the "chirp thread" and after I posted it was immediately closed. must be some forum glitch.
    edit- (I couldnt figure out where my post went)
    Dec 2018
    Ventura, CA
    Yes. Got a code 12 and 44. All I could note is using my voltage detector wand the black wire going to the motor is hot all the time. Other wires not showing anything when jumping R to G.
    Did you get my email?
    It was no glitch. The OP asked for his account to be removed and thread closed.
    Mar 2013
    Quote Originally Posted by Dad View Post
    Fair enough. I can only report what happened when I posted.
    What makes you think we need you to report anything?? We don't need your help in moderating this site as I've told you time after time.
    Thanks but stop it now.
    Mar 2013
    I didnt "report" it via the triangle. I made a reply to rundawg on what happened to me when he questioned my post (see post #3 and I deleted my post #2). That was my "report" in this thread. Again, I apologize for replying to a thread that you were closing as I posted. I had no idea it would post here and I had no idea that you were closing the other thread.
    I totally understand the moderating thing. I've completely stopped pressing the triangle unless it's a blatant crossing of the rules. This is "your" site, your rules, and it will be as you wish.
    Nov 2014
    Portland, Oregon, United States
    As yooooouuuuu wiiiissssshhhhh.
    I love that movie.
    I will now shut my pie hole.
    Sent from my SM-N950U using Tapatalk
    Jul 2012
    WA
    I’ve had decent luck using the universal zebra ecm motor tester to tell if the problem is the board or the motor module.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
