Page 3 of 3 FirstFirst 123
Results 27 to 32 of 32
  1. #27
    Feb 2019
    Quote Originally Posted by teddy bear View Post
    To confirm that the dehu is functioning, measure the condensate from the dehu for an hour. Your unit should remove 2-3 lbs./pints per hour.
    Also measure the temp/%RH of the dehu supply verses the air going into the return. This will confirm the amount of moisture being removed by comparing the dew point in and out.
    As others pointed out, any air from the home passing through the crawlspace will benefit from the dehumidifier.
    It takes a couple weeks to dry down the materials in the crawlspace. During windy damp weather, the dehu may run 50%-75% of the time. After dry down and when the outdoor dew points are below the dew point desired in the crawlspace, the dehu should run much less.
    A 68^F, 50%RH crawlspace is 49^F. Consider that outside vary from 60^F-75^F. During cold weather, the outdoor dew is much lower, usually equal to the evening low temperatures, but the crawlspace is cooler and may still have a small dehumidifier load.
    Someday when the dehu fails consider the Santa Fe Compact, my favorite. The unit you have should be large enough to do the job. Keeping your crawlspace dry will help keep your home dry!
    Keep us posted.
    Regards Teddy Bear
    Thanks for all of this info. You mention the Santa Fe Compact but do you have any experience with the Aprilaire units? If so? What do you think of them?
  2. #28
    Atlanta GA area
    The SanteFe's are more like Mercedes...
    Other brands are Fords and Chevy's...
    Grin!
    One gets what they pay for.
    Above all... avoid the big box store portables... they are junk, do not work well, use too much electricity, and rarely last more than 2-3-4 years.
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
  3. #29
    Madison, WI/Cape Coral, FL
    The dehu you have should do the job if it is functioning properly. Measure the condensate output for an hour along with the temp/%RH of input and output. Expect 2- 3 lbs. per hour of condensate. If less, the unit may need service.
    As long as it functions, I would use it. When it comes time for replacement, consider the Santa Fe.
    Keep us posted.
    Regards Teddy Bear
  4. #30
    Oct 2019
    TX
    Are santa fe dehumidifiers really that good? Mine Crane was working for 5 years but I accidentally broke it one week ago, but it seemed sometimes that it's not that warm as it could be
  5. #31
    The Santa Fe may be more dehumidifier than you need. Tell us about what you are trying to do and in what part of God's Green Earth you are in>
    Regards Teddy Bear
  6. #32
    Oct 2019
    TX
    I am a retired engineer visiting a friend of mine in Siberia. We are building a blockhouse of solid wood so I am looking for a powerful dehumidifier to keep the construction dry. For sure we will insulate the walls, floor etc. I still feel something like fust, though, and would like to help him avoid this in future
