Results 1 to 10 of 10
    Jan 2019
    RELATIVE HUMIDITY IN GUITAR SHOP / how to nail reading
    my new humidity controller reads 7 % difference from my Honeywell humidity meter reading ....?? I need to set up my new controller to keep a constant 48% in my guitar shop, but I believe the new controller will need calibration to read exact / accurate relative humidity ....how do I measure that in my shop ?? (without having to fabricate a psychrometer from 2 thermometers) ....I ordered a mini dial type hygrometer hoping that tells me exact / accurate reading ...pics attached, THANK YOU FOR THE HELP
    Madison, WI/Cape Coral, FL
    You need an accurate temperature gauge. Calibrate with ice water, 32^F. Note the adjusted temperature. Next take a metal vessel with warm water and slowly chill with ice until exterior metal fogs, this is the dew point. Using a psych chart, lookup the %RH of the air using the air temperature and dew point of the air. An example is 75^F air that fogs a metal vessel with 55^F water is 50%RH.
    Repeat calibration every week.
    Make sense?
    How are you going add or remove moisture from your shop. I would like that big gray instrument on the top rail. Where is this shop?
    Regards Teddy Bear
    Southold, NY
    Jan 2019
    thanks for the assist, may go this route once I get reading off my hygrometer in my shop and compare RH numbers, I also found how to calibrate my new controller so I'll play with that as well ....my shop is in Whidbey Island WA, and that primer'ed big body is my '63 Silvertone, which I replaned the fingerboard and refretted, now I have to wait for warm weather to shoot its new paint ....not parting with this guitar for many years, my kid may sort that out per my instructions after I'm gone ...haa ha ...thanks again -
    Jan 2019
    hey pecks, where do I obtain this psychrometer ?? .....
    Jan 2019
    I meant pecmsg, auto correct did me wrong
    Southold, NY
    I believe granger carries it
    Jan 2019
    I see Grainger sells a bunch of types of them, got it ....is this type of psychrometer THE way to nail exact / correct humidity in my shop ?? .....
    Southold, NY
    I’ve had mine 20+ years. Haven’t failed yet, no battery’s needed!
    Jan 2019
    ordered one !! will pick up at my local Grainger store tomorrow ....
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
