Thread: Oil failure
    May 2013
    Oil failure
    I need help on finding causes to oil failures in rack systems. Does anyone know of a good troubleshooting chart for oil failures?
    Moved to Refrigeration And Ice Making forum.
    Sep 2013
    Atlanta, GA
    How about you start with saying what you know to check for (and how to check) and let posters fill in the blanks for you. It would also be good to say what kind of systems you work on and what oil fail controls are used.
    Jan 2012
    Montreal, Canada
    No chart that Ive come across. What type of rack, oil separator, oil feed line regulator or pressure, oil level/pressure monitor on compressors, floats?
    Follow the path of oil in the system.
    From separator to compressor.
    Do all or some fail and wich ones random or further down or up stream?
    Trax oil? .. Have you had many power outages lately? Slugging?
    Sent from my SM-G955W using Tapatalk
    Nov 2014
    Northern Idaho
    Here you go. In addition to diagnosing actual oil return issues, make sure to also consider the electrical issues that can show up as an oil failure trip.
    May 2013
    Thank you for the replys. Gocougs. Thanks so much!
