+ Reply to Thread
Results 1 to 12 of 12
Thread: Canvas / flexible conectors
    Jan 2019
    Crystal Lake
    looking for a good source for canvas / flexible connector in an add size. i can work with something that is 1 1/2" 1 1/2" or 2" and 1 1/2"- that is metal canvas metal. can find anything in that size anywhere. most have 3" of canvas in the middle and I only have about 4.50" to work with maybe 5". any input will be great
    Mar 2015
    Tx
    Like we did in the old days, make it
    Jan 2019
    Crystal Lake
    Quote Originally Posted by oldguy1949 View Post
    It starts looking like that is going to be my only way. This is when I miss my old man as he was one of the "old days" HVAC guys and will whip one out from nowhere.
    Mar 2016
    Pahrump, NV
    Trim the metal down to 1" on each side. I don't think you will destroy any "listing" or standard in doing so. Then you would have a peice that is 5" wide instead of 7".
    It's an upside down world we live in.
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    Can you cut back either the duct ends or the metal edges of the available rag-joint material to get to where you need to be? Or both?
    PHM
    Quote Originally Posted by adamf79 View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
    Jan 2019
    Crystal Lake
    Quote Originally Posted by David Goodman View Post
    PHM
    That was the plan untill I re mesure yesturday and I only have about 4" to work with. So now im tryint to figure out and see how I can do this. Maybe do 1" metal on one end. and bent it to sit on the top of the coil flange. then 3" canvis and 1" for s connection. should be total of 4.5" .5" shoudl be that big of the deal.
    Sep 2013
    Wi
    what will a wrinkle hurt
    Jan 2019
    Crystal Lake
    Quote Originally Posted by Galt View Post
    Will be right above the case coil don't want to restrict too much of airflow.
    Southold, NY
    Don’t most systems require 24 or36” of straight pipe before bends, takeoffs, transition?
    Jan 2019
    Crystal Lake
    Never hear off. Lol 😆
    Mar 2015
    Tx
    Wrinkle is fine. Could you make it to slip on the outside of the existing duct not using s/drives , just screws & mastic .
    Dec 2006
    Vancouver, B.C.
    What’s the point of using the flex if you are just going to pull it so taught that it’s basically hard?
    Cut back the metal so that you have a 5” finished flex duct then insert it into that 4” space. It will work like it is supposed to and isolate the vibrations from the unit. It will also be much easier to install. That’s your solution and it also happens to be standard practice so win-win for everyone!
    Quickly, I must hurry, for there go my people and I am their leader!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
