Results 1 to 10 of 10
Thread: Wood to gas
    Aug 2001
    Pavilion, NY
    Wood to gas
    I dont usually post and this is probably not rhe absolute best job but i was bored. Customer had an outdoor wood boiler and was getting older and didnt want to deal with it. The space was super limited and we moved the 40gal elec water heater out of this closet to put in the propane boiler. This was in the middle of nowhere and i think it came out descent
    'The more you know, the more you realize you don't know'
  2. Likes 20below liked this post
  3. #2
    all your nice copper work and it goes to the blue pex i hate that stuff i will always use copper when my clients allow it pex is for those who don't want to learn the craft of soldering or pro press etc
  4. #3
    Aug 2001
    Pavilion, NY
    Quote Originally Posted by pctech View Post
    Yeah,,, unfortunatly when we relocated the tank type water heater, the tank was placed 15' away and we needed to fish the water line through a ceiling. That wasnt going to happen with copper.
  5. #4
    I agree. Where does the condensate pump's discharge go?
    PHM
    Quote Originally Posted by kangaroogod View Post
    PHM
  6. #5
    Aug 2001
    Pavilion, NY
    PHM
    Runs to a laundry tub 15' away
  7. #6
    i would fish the copper so many feet at a time tied to the pex snake it can be done
  8. #7
    Oct 2011
    Gladstone, Oregon (Portland)
    Is your 3/4 pvc mechanically fastened to the drain outlet or is it just pushed up into it?
  9. #8
    Mar 2013
    Billington Heights, NY
    It'll happen with Fostapex though, which looks nicer. What are the blank copper stubs for?
  10. #9
    Aug 2001
    Pavilion, NY
    Quote Originally Posted by HVAC_Marc View Post
    The stubs are part of the manifold and are capped. They are there for an indirect, if you use an indirect you can cut the capped copper and pipe 1" off the stubs so it would be on the primary loop. The primary loop, secondary loop and indirect pump are all controlled by the boiler. With a call for indirect, it will energize the indirect pump and de-energize the secondary loop pump providing priority.
  11. Likes HVAC_Marc liked this post
  12. #10
    Aug 2001
    Pavilion, NY
    Quote Originally Posted by Adlerberts-Protege View Post
    The boiler has a 1/2 mpt, the 3/4 pvc connects to a pvx 1/2fm x 3/4 glue to a coupling. We also add a tee or drill a hole in the top of the horozontal 90 to create a vented drain. If the 3/4 falls below water level of the pump it would be a double trap and the unit would not drain. The hole prevents this...
