Results 14 to 26 of 48
    Jun 2011
    NE Ohio
    Quote Originally Posted by gravity View Post
    with sterling 95/5
    solder joints look nice .... definitely a fine art to soldering copper
    "All that is necessary for the triumph of evil is that good men do nothing." (hvacrskills)
    II CORINTHIANS 3:6
    “Who also hath made us able ministers of the new testament; not of the letter, but of the spirit: for the letter killeth, but the spirit giveth life.”
    the spirit of the law
    The intended meaning of a law by those who wrote it, as opposed to a literal interpretation thereof.
    Amarillo by mornin'
    I'm jealous over the solder joints, picture perfect.
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
    Jul 2009
    Columbia, MD
    Use a small tip and put the heat further back on the joint. Use small amount of flux and use your finger to flick the bean on the bottom
    Amarillo by mornin'
    ...use your finger to flick the bean...
    Albert Einstein
  5. Likes UrAverageAguy liked this post
  6. #18
    Jul 2009
    Columbia, MD
    Funny...my wife has never heard that term. I asked her about a week ago
  7. #19
    Jul 2009
    Columbia, MD
    Bead*
  8. #20
    Amarillo by mornin'
    Sorry...couldn't resist. Nice work anyways. Good to see work like this.
    Albert Einstein
  9. #21
    Jul 2009
    Columbia, MD
    It is in my house so i had to do some what of a good job or I’d never hear the end of it
  10. #22
    Aug 2001
    Pavilion, NY
    Is there a vaccum relief valve on the top or just a prv?
    'The more you know, the more you realize you don't know'
  11. #23
    Jul 2009
    Columbia, MD
    There is a vacuum relief and a prv. I didnt need the vacuum relief because my heater is lower than all my pipes. But rheem will void the warranty on the tank if removed.
    The tank is polybutylene and if it were to be in a vacuum from someone draining it wrong or a siphoning effect if installed in a penthouse, it could crack the tank
  12. #24
    Oct 2014
    Columbus, Ohio
    Interesting to know it uses a gasket seal, i was wondering how they would connect since the whole thing is plastic. The 0.2 degrees per hour heat loss rating is pretty insane on those Marathons. Pretty sure teflon isn't going to do jack on a gasket seal, good work using the torque wrench. Most common failure of gasket seals is gasket/o-ring being pinched by overtightening.
  13. #25
    i like your work but where is the the temp pressure relief valve piping that should terminate 6 in from the floor?
  14. #26
    i did not notice it until i looked at the pictures again why run the 220 line in conduit part way up then leave it exposed romex? in my area we have to have it in conduit or sealtite all the way to the panel or the closest junction box
