Thread: Cotter pins
    Nov 2010
    indiana
    Cotter pins
    I maintain and service a dish accumulater that is about 8 years old and the cotter pins that hold the tray holders are breaking causing mayhem at the middle school lunch room. I tried using what the on-site mechanic had in stock but those broke too. Is there a strongest, longest lasting pin out there?
    May 2014
    Bay Area California
    Maybe a washer to relieve wear on the cotter pin.
    Oct 2012
    riverside calif
    Check McMaster Carr book all sorts of material and strengths. Is there play in hole that pin goes in? That comes into play if there is movement also.
    Sent from the van with a/c on.
    Sent from the van with the a/c on.
