+ Reply to Thread
Thread: Rectangular Tee 45 Degree Diverging branch, SMACNA OR ASHRAE?
    Jan 2019
    I have just realized a huge difference in Loss coefficients values between SMACNA's Table 14-14 N, and ASHRAE's SR5-13, Rectangular Tee 45 degree diverging branch. ASHRAE seems to have much higher coefficient values for a given flow rate ratio (Qb/Qc).
    Which standard do you recommend I follow?
    Thanks,
    Baradei
    New Mexico
    Maybe one has turning vanes and the other doesn't. Or long sweep vs short. There's likely a difference somewhere.
    We are here on Earth to fart around ......Kurt Vonnegut
    You can be anything you want......As long as you don't suck at it.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Mar 2015
    Tx
    I allways used SMACNA only because every plan/spec job I did required a SMACNA Duct Construction manual be with us on the job. Yes did get asked to see it on one job & only one.
    New Mexico
    Quote Originally Posted by oldguy1949 View Post
    Who required this?
    Mar 2015
    Tx
    Quote Originally Posted by hvacker View Post
    Who required this?
    Written in the specs by the engineer/architect. You allways read the specs before bidding don't you ? On a school job that had 3 suspended air handlers the engineer buried the spec on the safety drain pans in the book & not on the plans ,had to be 20 gauge or thicker & the sob actually got on a ladder with a sheetmetal guage when doing the final inspection.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
