    Jan 2019
    What is the difference between the Alpineair 2210 and 2410 systems?
    Can anyone tell me what the difference is between these two systems? also any reconditions for a two zone home. Thanks.
    Aug 2015
    Buffalo,NY
    Should be the size
    There is no alpineair. That is an online company only. The difference is the size or the cabinet and media filter. That difference has a direct relation to the amount of restriction to the airflow depending on the cfm quantity needs of the system.
    Only way to know which system is needed is to perform airflow tests to see which is needed for that system or if either will work properly with the system.
    Sep 2014
    NW Arkansas
    This will show you the size difference and some other specs. Your HVAC company can do a Manual J, and D for you and pair the correct one(s) to your system.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
